Old 03-23-2002, 01:30 PM
panozracer panozracer is offline
Question about fuel injectors?
I have found that when I look for fuel injectors there are two kinds, low impedance and hi impedance. What is the difference between the two? Which one is better for me if I was planning on turbocharging my car that is NA stock?
Old 03-24-2002, 02:18 AM
Holyterror's Avatar
Holyterror Holyterror is offline
Well, with a turbocharger, you're going to need more fuel so a low-impedence, high-output injector is a must. High impedence injectors are basically for OEM-replacement applications. Specifics for you engine/turbo combination are neccessary to get more in-depth than that.
"There are no substitutions for revolutions."
Member of AF's Slide Squad (Member #05)
Old 03-24-2002, 04:55 PM
texan's Avatar
texan texan is offline
Writer Mod
You can get either peak-and-hold (low impedance) or saturated (high impedance) injectors in a variety of sizes, ranging up to gigantic. Which you need to use largely depends on what your car currently runs, but since you didn't say what car you have I can't answer the question.
'03 Corvette Z06
'99 Prelude SH
