Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 03-03-2005, 05:48 PM
Madpotato Madpotato is offline
Smile Cigarette lighter plug not working
I have a 1999 Mercury Cougar
About two days ago I pulled out a GPS adapter from my cigarette lighter socket. The plug from the GPS broke inside my cigarette lighter socket. After removing the pieces from the broken plug, the cigarette lighter socket does not work. I talked briefly with a mechanic and they said that a fuse is probably blown. I searched all over the place I see no fuse for that socket. I looked below drivers side fuse box and the drivers side fuse box below the hood. Can anyone tell me where the fuse that operates the cigarette lighter socket is located and which fuse is it. Or are there any ideas why the cigarette lighter socket does not work. Thank you
Old 03-03-2005, 06:31 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
its fuse #27 under the drivers side footwell.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-05-2005, 04:57 PM
Talking It worked
Thanks alot I really appreciate the excellent help beyondloadedse.
Old 06-12-2005, 06:20 PM
trcarrera trcarrera is offline
My Cigarette lighter plug is not working. I know fuse #27 under the drivers side footwell is blown. When I try to put a new fuse in it blows again and I pulled some of the wires out from behind the lighter plug and I didnt see any cerosion. Any ideas I would greatly appreciate.
Thanks
Old 06-12-2005, 10:11 PM
KimMG KimMG is offline
AF - Advisor
Re: Cigarette lighter plug not working
trcarrera-
Disconnect the the lighter and see if the fuse still blows.
Using a wiring diagram, you can trace the circuit until you find the short.
