Old 03-03-2005, 05:46 PM
ponypal2 ponypal2 is offline
Cool HUD problems
I have a 98 gtp and my wife has a 00 gtp and both of hud's fade out after driving for awhile. Are there any remedies I can do for this or replacement is necessary?
Old 03-03-2005, 06:34 PM
BIG-L's Avatar
BIG-L BIG-L is offline
This fix should take care of your fading problem
1. Remove HUD from car.
2. Remove 4 Torix screws from top of HUD
3. Remove ribbon cable and small 2-wire cable from circuit board.
4. Remove circuit board.
5. On the board there is a small photocell, the problem is that the cell has a cold solder joint. The cell is a 1/3-inch
Circle with a black square in the center. All you need to do is resolder the two legs.
6. Put everything back.
I was unable to find a replacement cell at radio shack.
The cell produces a small amount of voltage. The more light the more voltage. 0-.75 volts. My cell was working fine but the joint was loose. When the board heated up it lost the joint increased resistance to the point that the HUD lost the voltage reference.Hope this helps....~Larry~
ClubGP Member 6530
Since 2001
Old 08-19-2005, 09:38 AM
Bassett72 Bassett72 is offline
Can someone provide instructions on how to take the HUD out? Thanks
Old 10-04-2005, 09:29 PM
thatnigga thatnigga is offline
Re: HUD problems
I have a 2001 with the exact same problem. But my board doesn't look anything like this......has anyone seen this is a 01 GP?
Old 11-22-2005, 05:04 PM
tiggerluke tiggerluke is offline
Re: HUD problems
HEY BIG-L Thanks for the great info. However, the URL's for the images nolonger exist.
