Old 03-03-2005, 06:41 PM
gspgretchen gspgretchen is offline
98 Windstar codes
98 windstar code DTC P0171, System to lean Bank 1. It dies at idle occasionally, and cuts out at 4000 rpm in driveway. With a load on it will go to 4800 before shifting with no problems. Changed plugs and fuel filter. Local parts store says might be O2 sensor, fuel pressure regulator or bad injectiors. I need to know which is Bank 1 and what might be the logical place to start checking for problem parts. Thanx Mike.
Old 03-03-2005, 07:26 PM
crazymoon crazymoon is offline
could be the idle air control and the MAF. i would start there
Old 03-03-2005, 09:41 PM
12Ounce 12Ounce is offline
Re: 98 Windstar codes
Think of the engine as swung around 90 degreees to the position it would be in a regular old rear wheel drive vehicle. The RH side of the engine is bank #1...cyls #1 - #3.
Or in case of the 'star, the Bank #1 is near the firewall.
