Old 03-03-2005, 04:25 PM
Jayman05 Jayman05 is offline
Send a message via Yahoo to Jayman05
94 GA head lights
Ok here is the deal i was driving i shut off t he car came back out and turned on the head lights but no go.. the only way they turn on is buy pulling on back on the head light switch and then when i let go i shuts off!!! checked the fuses
Old 03-03-2005, 04:54 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 94 GA head lights
If by moving the switch around they come on, it has to be a bad connection/loose wire. I would remove the switch and check for a contact problem. Good Luck.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-03-2005, 05:12 PM
how would i remove the switch or stuff ..
Old 03-03-2005, 05:46 PM
FormulaLT1's Avatar
Fight the powwa!!!
What do you mean by pulling on the back of the switch?. The back of the switch if I am thinking about the same thing should be in the dash.
John
Old 03-04-2005, 10:06 AM
no no the low high beam switch.. like on the left side of the steering collum
Old 03-04-2005, 06:23 PM
Knifeblade Knifeblade is offline
Run a search in this forum for replacing the light switch, someone else recently had to pull the switch out of the column to fix a very similar problem you have.
