Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-03-2005, 03:18 PM
Mattcaton88888 Mattcaton88888 is offline
radiator leak?
My 73k mile 87 Ranger has some cooling problems. The problem I have is that after changing the thermostat, flushing, and changing the coolant my truck after about a week the coolant level in the radiator droped. After adding coolant twice over a two week period it continued to drop so I purchased radiator stop leak. The tempurature level was fine for about a week then the same problem continued. Does it require mechanical repair or is there something I am overlooking that can stop this problem. Please point me in the right direction on what I need to do.
Thank You,
Matt Caton
Old 03-03-2005, 04:05 PM
Psychopete Psychopete is offline
Re: radiator leak?
Thank You,
Matt Caton
Check the oil for water, you may have a cracked a head.
Old 03-03-2005, 08:54 PM
rdavid8221 rdavid8221 is offline
Re: radiator leak?
Do you smell antifreeze? Is there a visible leak? Do you see white unusual smoke from the tail pipe? You need to give better info to receive a better resolution. Check these things, because it could be a number of problems...
Old 03-03-2005, 09:46 PM
re: radiator leak?
yes i do smell antifreeze while driving especially when the heater is on. and also for the first 10-15 mins of driving smoke comes from the tail pipe
Old 03-03-2005, 10:04 PM
Re: re: radiator leak?
You need to check your heater core. If you live in a cold climate you will see white smoke for a while. Big clouds of smoke are bad. That could indicate a defective head gasket. If the smoke diminishes in a short time, there is usually nothing to worry about. Seems to be a heater core.
Old 03-04-2005, 12:35 PM
thnak you very much for the advice. how much on average would a heater core cost and is it to hard to change or would it require bringing it to a shop.
Old 03-04-2005, 06:20 PM
Re: radiator leak?
The heater core should be no more than $50.00. You can definitely do the job yourself. The hardest part is gettting under the dash on the passenger side. This is a very easy job.
