Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-03-2005, 02:38 PM
UziRags UziRags is offline
When I stop It wont restart O_O Quick question.
Hello!
I have a 97 Olds 88 and it never fails...When I drive in to work (8 Miles) if I stop the car it will refuse to start again for about an hour or 2. It jsut cranks until the battery starts to heave with exhaustion and I finally give up and call for a ride. If I come back to it though in say 2 hours or so, BANG! It starts right up and life is good again. Any ideas on what parts I should start tearing out to replace?
Thanks!
Rags
Old 03-03-2005, 09:44 PM
Hansnet's Avatar
Hansnet Hansnet is offline
fuel pressure regulator?
Old 03-09-2005, 10:56 AM
Re: When I stop It wont restart O_O Quick question.
HRmmm,..... Maybe I'll give it a try..
Old 03-09-2005, 10:22 PM
ramjet ramjet is offline
won't shift to reverse at all when shifted from
neutral to drive will finally go into drive
then shifts perfect except no reverse
Old 03-15-2005, 08:22 PM
turtlenut2 turtlenut2 is offline
Question Re: Re: When I stop It wont restart O_O Quick question.
I'm having the same trouble with my 92 olds 88 3.8. Let me know how that works out.
I had my brother-in-law put a scan on it today and it came up with code 17 and 21. I'm going tommorow to get a intake temp sensor, but I'm not sure what the other code is for. Had something to do with the RPM reading wrong.
Old 03-16-2005, 11:56 PM
Marco49 Marco49 is offline
Send a message via MSN to Marco49
UziRags---> check the oil presure sensor, the temperature sensor, just disconect one day and turn off after 8 miles, if the problem occur again, then chek the relays, this is the info that i have at this time.
Old 03-23-2005, 04:57 PM
Was told by 2 good mechanics, check out the crank sensor. Also try tapping on the ECU when it won't start.
