Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-03-2005, 01:30 PM
jogi jogi is offline
Unhappy 97 chevy Suburban code PO172, PO175
Engine light comes on and after sometime goes off.
Chip came up with these codes PO172 , PO175
Please could some one help what to do next
Thanks
Old 03-03-2005, 01:43 PM
bad68chev bad68chev is offline
Re: 97 chevy Suburban code PO172, PO175
p0172 and p0175 are bank 1 rich and bank 2 rich. If you have access to a scan tool, I would check the fuel trim and see if engine is running rich all the time. I'm not sure about Chevy, But on Nissan if both banks are too lean or too rich, usually the cause is the Mass Air Flow sensor. If you have a buddy with the same truck you could swap MAF sensors and see if problem goes away on your truck and then comes up on theirs, that way you would know if its bad before you replace it. Other problems could also be fuel pressure regulator, o2 sensors, etc.
