Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-03-2005, 11:32 AM
porsch964 porsch964 is offline
Fan Clutch on 98 Rodeo
Anybody knows what are the symptoms of a bad Fan Clutch on 6 Cylinders W 3.2L and how can it be tested?
Old 03-03-2005, 12:04 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Fan Clutch on 98 Rodeo
With the engine off. grab on to it and pull it back and forth (toward the rad). If it moves it is bad.
Fan cultches on Isuzu are noise at start up.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-03-2005, 12:19 PM
Re: Re: Fan Clutch on 98 Rodeo
It ran loud, there’s is no play. It sound like a wind tunnel and not overheating
Old 03-03-2005, 07:50 PM
rodeo02 rodeo02 is offline
Re: Re: Re: Fan Clutch on 98 Rodeo
If the clutch fan roars all the time, it's not doing it's job & will need to be replaced. The fan should slip at high speeds and be very quiet if it's internal valving & silicone fluid are working as they should. The fan should only kick in on a hot engine at low RPM's. The fan may occationally roar on a cold take-off, but it should stop by the next acceleration.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-04-2005, 06:53 PM
Re: Re: Re: Re: Fan Clutch on 98 Rodeo
G/luck
Joel
Thank You, I am going to look into it. How difficult is it to replace the Fan Clutch and where can I get one, my local Auto Zone doesn’t carry it
