Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-03-2005, 10:45 AM
vbeurotuner204's Avatar
vbeurotuner204 vbeurotuner204 is offline
Send a message via AIM to vbeurotuner204
Clutch Not Right
Alright guys, searched clutch problems and found a lot, just not anything on my problem. When I first start my car, a loud grinding noise comes from the tranny until I let the clutch out. For about 5 to 10 minutes after startup everytime the clutch is in the grinding starts again. Any ideas?
'97 GS 420A 5-Spd
Cold Air
Cat-Back
Plugs/Wires
Ball Bearing Shift Linkages
Coil overs and 17's
Old 03-03-2005, 10:49 AM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Re: Clutch Not Right
Throwout bearing.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 03-03-2005, 02:24 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: Clutch Not Right
Originally Posted by TsiTalon9587
Throwout bearing.
Bingo!
My RX-7 had those symptoms and that's exactly what the problem was. You might as well do the entire kit while you are there doing the bearing. It's only the cost of parts at that point.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-03-2005, 02:27 PM
Thanks guys you've confirmed what I was thinking. So now that I know whats wrong which kit would you recommend. BTW trying to work with a 250-350 budget.
'97 GS 420A 5-Spd
Cold Air
Cat-Back
Plugs/Wires
Coil overs and 17's
Old 03-04-2005, 07:23 AM
I'm not really sure what to recommend? I see that you have a GS so your aren't going to be making a ton of power (Sorry, not trying to be an ass or anything). So I don't know that you will have to go all out and get the ACT 2100 or anything. Maybe just a decent kit with all the bearings, clutch, pressure plate, etc.
You might want to wait and see what others think.
1997 Spyder GS-T
5-Speed
