Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-03-2005, 10:28 AM
caminsc5 caminsc5 is offline
Send a message via AIM to caminsc5 Send a message via Yahoo to caminsc5
Exclamation G/f's 92 lude losing oil like crazy
girlfriend has a '92 prelude. when it is sittin still not cranked it leaks oil in a steady stream from up under the car.......when you crank the car, the oil just pours out from under the car. does anyone know what this could be?? please respond. thanks!
sitting still-- leaks in a stream
cranked--pours out
Old 03-03-2005, 02:19 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: G/f's 92 lude losing oil like crazy
Make sure all your bolts are tight. It's difficult to pinpoint an oil leak if you don't take a look under there to see where it is coming from.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 03-03-2005, 02:36 PM
i looked and its not the oil filter, or oil pan.....theres some type of a plug that gets alot of oil in it.
Old 03-06-2005, 10:03 AM
vtecludeguy vtecludeguy is offline
check your valve cover too to see if it's just a gasket, or if the valve cover is cracked... it's leaking like that b/c of the oil pressure built up in the engine... then when you start up the car, it's getting about 60 PSI, so it's most def. gonna pour it out... but check your valve cover, also check your head gasket and your head to see if it's damaged too, you might could also just check your block for any hairline cracks or anything like that.
Old 03-06-2005, 09:54 PM
joellthomas joellthomas is offline
Oil pressure sending unit ???
Old 03-09-2005, 06:11 AM
computerdude14 computerdude14 is offline
cranked--pours out
which side of the motor is it leaking from? if its between the motor and tranny then its prolly the rear main seal like my 91 lude has the same sort of problem, only mine only pours out wen its cranking, but it does leak a bit while sitting overnight. very possibly something else tho like they said already, check the oil filter to make sure its securely attached and that the rubber seal thing on the filter isnt pinched or damaged and stuff, as well as the other gaskets and stuff like they said the oil pans etc.
Old 03-09-2005, 09:24 PM
as long as the sending unit is still in the hole, it shouldn't pour out any oil. at the most it would simply drip if it wasn't on there tight enough.
Old 04-06-2005, 07:34 AM
Gammey3's Avatar
Gammey3 Gammey3 is offline
cranked--pours out
I had the same problem with my 92 prelude (2.3 L) it turned out to be the cam seal had gone bad, the part only cost abou t 15-20 dollars at any parts store
Old 04-08-2005, 05:25 PM
2.3's and vtec's have an oil cooler mounted between the oil filter and the block. There's an o-ring that seal the oil in the cooler. My 93 2.3 had this o-ring cracked and would leak on to the exhaust pipe. It had an oil smell all the time. You just remove the oil filter, screw the cooler bolt/pipe out and replace the o-ring on the cooler, and reinstall.
Old 02-09-2008, 08:58 PM
newtuner08 newtuner08 is offline
Just had the same prob. on my 92 Lude. My front balance shaft seal is spit out. Remove timing cover to find the leak right below P/S pump. I would reccomend replacing the oil soaked belts. Interference engine.
Old 02-09-2008, 09:43 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
hey newtuner this thread is almost three years old
