Old 03-03-2005, 10:15 AM
BIG-L's Avatar
BIG-L BIG-L is offline
New gauge coming soon
This will be the next gauge im going to buy or for some the only gauge you will need and it also read's the DTC codes you wouldnt need a scanner.This gauge is for OBDII car's and is going to also be released in red soon,but for now it is blue.It will be 206 bucks shipped and is plug and play !
~Larry~
The Interceptor is capable of displaying the following parameters. Not all are
supported be every vehicle so there is no guarantee that each individual vehicle will
have every one of these available. If the vehicle is broadcasting the parameter, it WILL
be available for display.
* RPM
* MPH
* Intake Air Temperature
* Mass Air Flow Sensor Frequency
* Mass Air Flow Sensor (lb/min.)
* Engine Coolant Temperature
* Injector Pulse Width (bank 1 and 2 if supported)
* Long Term Fuel Trim (bank 1 and 2 if supported)
* Short Term Fuel Trim (bank 1 and 2 if supported)
* O2 Sensor Voltage (bank 1 and 2 if supported)
* Manifold Pressure in PSI (Boost pressure for turbo/supercharger
applications)
* Ignition Advance
* Knock Retard
* Engine Run Time
* Battery Voltage
* Transmission Temperature
* Idle air Control Counts
* Throttle Position Percentage
* Throttle Position Voltage
* Engine Load
The Interceptor gauge has a 52mm (2 1/16") diameter and will fit in all standard gauge
pods of this size. A 3.5' cable is included with appropriate OBD2 connector. An optional
splitter cable is available to connect two Interceptors at one time.
Accessing the function menu involves simply pushing both buttons simultaneously. From
the menu you can enter a recording mode, where the Interceptor will return to normal scan
mode but will start recording the displayed data automatically when the throttle exceeds
70%. Approxoximately 35-40 seconds of data will be stored. Back at the menu screen you
can choose to replay the stored data on the Interceptor display. From the same menu
you can also instruct the unit to display all stored trouble codes and then clear them if
desired.
Power is supplied to the unit by the OBD2 port, so no additional wiring is needed, simply
plug-and-play!
Warranty
ClubGP Member 6530
Since 2001
Old 03-03-2005, 09:48 PM
stlwagon stlwagon is offline
Re: New gauge coming soon
Larry- where did you find it?
Old 03-03-2005, 09:53 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: New gauge coming soon
I don't care when he found it. I want to know when it's coming out in red.
Will order that day.
Old 03-04-2005, 03:19 AM
BIG-L's Avatar
Opps,I was so excited when I seen it and wanted to share the information with everyone,I forgot to included the link.
www.aeroforcetech.com/
Old 03-04-2005, 06:37 AM
KX2000GTP KX2000GTP is offline
doesn't it say in the description that it reads the trouble codes? aren't those the DTC?
Old 03-04-2005, 08:06 AM
That does it. Just made it a real must.
Old 03-04-2005, 09:05 AM
BIG-L's Avatar
Thank's,I fixed it.Thats what I should have said That it does read's/clears codes and you dont need a scanner.
Old 03-04-2005, 09:15 AM
Re: Re: Re: New gauge coming soon
Oh sure, NOW you tell use.
Old 03-04-2005, 09:33 AM
BIG-L's Avatar
Re: Re: Re: Re: New gauge coming soon
Thats why I was so excited .
Old 03-04-2005, 11:17 AM
Re: Re: Re: Re: Re: New gauge coming soon
It doesn't take much lately. We need to talk.
That is a great find. Will have to have that. It's less then buying a scanner.
Old 03-04-2005, 11:55 AM
BIG-L's Avatar
Ive been needing a scaner for sometime now,plus you dont need all the other gauges,like tranny,water temp,boost which would fill up a pod very quickly.Just get the 2 gauge pod and have oil pressure and the Interceptor.
Old 03-04-2005, 09:40 PM
Let me know when they come out in red. I'll have one. If you could get enough guys that want one, MAYBE we could get a discount.
Old 03-05-2005, 05:53 PM
I would definetly be up for doing that.
So this really is an all in one gauge. is there any reason to have more that one if you have this one?
maybe if you wanted to monitor more than 2 readings i guess...
Old 03-05-2005, 05:56 PM
Yeah...didn't see that at first, my bad
Old 03-06-2005, 08:13 AM
2kBlkGTP 2kBlkGTP is offline
if your go onto the images page on this gauges website and watch the video, while the numbers are changing quickly they seem to blur into one another so you cant even tell what it says. I e-mailed the guy about this and he said it was just the camera thats doing this bluring. when it comes out in red i am getting one also
