Old 03-03-2005, 10:08 AM
a bastard a bastard is offline
Exclamation how does the SL handle?
hey guys everyone raves about the handling on the VR4 but what about the FWD 3ks? also should i buy a low mile 97 SL or a high mile sketchy 91 stealth rt/tt?
Old 03-03-2005, 11:20 AM
Igovert500's Avatar
blue + red light magnet
Re: how does the SL handle?
Test drive em both and you can decide.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-03-2005, 01:29 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
I havent gotten a chance to drive a VR4 very much (yet) but the SL was fun for me except around tight fast turns somtimes I would get wheel hop. It accelerates with better traction than my mom's sienna but then again the sienna tires are thin and it has a bit more power I think. They'll both hold a good edge around turns but the SL won't be able to accelerate out of the turn as fast.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 03-03-2005, 02:24 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
You must have had an automatic Thorun? If the SL is an auto, then i'd go w/ the TT. I like the handling of my 94 SL around turns, i'd compare it to being as good as my 92 Integra was for tight turn handling. But i'd test drive both first, if the TT seems good, then i'd definitely go with it over the SL anyday.
Old 03-03-2005, 02:55 PM
Thourun's Avatar
I had a 5spd.
1995 3000GT VR-4
Old 03-03-2005, 06:00 PM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
The SL handles quite well, theres minimal body roll and with the tires i have understeer reall isnt that bad.
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 03-03-2005, 06:17 PM
StealthModifier StealthModifier is offline
My ES handles great.. ive drove many other cars an i like drivin mine the best. I think it even rides smoother that my moms 96 ls400
Old 03-03-2005, 08:38 PM
mark2249 mark2249 is offline
handles fine, but awd id better
Old 03-04-2005, 03:42 PM
yeah it sure id.
Old 03-04-2005, 05:00 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
: yes awd id better. but my 93 base 3000GT has upgraded sway bars and the difference is night and day from stock. handling is awesome now!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-04-2005, 05:46 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
as igovert500 said, drive them yourself and you make the decision.
i think thourun is about right, going into corners at a faster speed it might get a little jumpy on you.
but at the same time, i've only driven 2 sl's and i didnt do too much cornering so
thourun tends to have an unbiased opinion, which is a good thing, so take into consideration of what was said, go drive them yourself and then make your decision
i can tell you its a smooth ride
Old 03-04-2005, 09:44 PM
Thourun's Avatar
Also remember that every car is differnt since the parts wear differently because of the different lives the car's have lead. Go drive them and you'll get a better understanding than anyone here could impart on you with words.
1995 3000GT VR-4
