Old 03-03-2005, 10:33 AM
tarcher1216 tarcher1216 is offline
Possible Tranmission problem???
Hello I have a 2000 GL and lately while drive normal speeds 25 to 65 mph the car seems to jerk. I noticed the tach and can see the rpms moving up and down which corresponds to the feeling of the jerking. I let up on the gas pedal and it seems to stop. However there have been times when I press down on the gas pedal again it starts up again. But for the most part the car run smooth no rough idle at all and easy start. It seems that it strans to shift into overdrive and once there runs fine but it struggles before the shift occurs. Can anyone help with suggestions or ideas? I hate to take off work to drive 75 miles one way to the nearest dealer and have to wait all day for something that might be fixed locally. Thanks for your help. I hope I explained my problem if not ask questions. I'll try to reply like I have knowledge HA HA I'm just a consultant not a mechanic.
Old 03-03-2005, 03:31 PM
medicdave medicdave is offline
Re: Possible Tranmission problem???
Have you checked the following?
- Transmission fluid level
- Transmission fluid color, smell
How many miles on the car? Have you had the transmission fluid changed at the correct intervals?
[medic]Dave
Old 03-04-2005, 04:03 AM
Re: Re: Possible Tranmission problem???
[medic]Dave
Hello., I have had the fluid changed at 51500 miles just over the 50,000 mile check . The fluid looks like tranny fluid (pink to red) and the smell smells like tranny fluid. So to me nothing out of the ordinary. Any other questions or ideas would help. Thanks for your response. the current mileage is 68254
Old 03-09-2005, 06:10 AM
panzer dragoon panzer dragoon is offline
there is a shift valve on the tranny that sometimes goes out. Do a search on this forum for the info. Otherwise I would just manually shift the tranny or put the tranny in 3rd and not use Overdrive. The Overdrive part of the 4T65 tranny seems to have the most problems. Manually shifting will most likely work.
later edit: http://www.automotiveforums.com/vbul...smission+valve
Old 04-26-2005, 03:00 PM
rangerdoc rangerdoc is offline
Our transmission just started doing something similar last week. The car feels mildly jerky when driving at about 70 on the interstate, or trying to go up a low grade. The fluid was changed at 30,000 miles, when the transmission was rebuilt the FIRST time (under warranty, thank God!), it's now been about 50,000 miles and seems to be doing about the same thing. The fluid level is fine, but it does smell slighly burnt. My husband belives it could be the lock-up on the torque converter. I actually have it in to a reputable transmission repair shop in town today. I'm hoping the damages aren't over $500.
Old 04-26-2005, 03:03 PM
Re: Re: Re: Possible Tranmission problem???
Forgot to mention that it's making a whining sound, too, when in gear.
Old 04-26-2005, 04:12 PM
Re: Re: Re: Re: Possible Tranmission problem???
When you start hearing the whining sound usually that means that the overdrive is starting to go out and fast for the 4t65. Take it in right away.
Old 04-26-2005, 05:10 PM
Just got the results from the repair shop. He said based upon the OBDII codes recovered and the symptoms, we need to trade it in ASAP.
