Old 03-03-2005, 09:12 AM
Arshem Arshem is offline
Send a message via MSN to Arshem Send a message via Yahoo to Arshem
Unhappy 1990 LeSabre Dying
Well from what i read I am at a battle...I bought the car a few days ago(had to have one) for 500, it has 196K on it, but like i said...HAD to have one. Well there was only a few problems with it, turnsignla doesn't work(but hazards do and the fuse is good), and no antanna, well i was driving home last night, drove about 6 miles then it died(2 streets down from my house). Tried and tried to crank it over and it wouldn't start, It's try to fire, cranking, but it wouldn't fire up. It was 2 am so i didn't get a good look at it...all the service engine lights came on, and i was going about 60 then AS SOON as i hit the brakes, it died.
Any Suggestions would be appreiciated. Thanks
Arshem
Old 03-04-2005, 11:55 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Usually when an engine just quits out of nowhere, my first opinion is of a fuel delivery interuption issue. Before cranking the motor, roll the key to the run position, not start, and listen towards the rear car for the fule pump, you should hear it come on (humm/whine) for a second or 2 when it primes up the system. No sound? Dead fuel pump (MAYBE)
Why "(MAYBE)"?
These cars have more than their fair share of electrical malfunctions, and since you mentioned it just died when you hit the brakes, I'm thinking it's something else.
But, first things first, make sure you have a running pump.
Old 03-08-2005, 09:56 AM
Re: 1990 LeSabre Dying
UPDATE:
It was the oxygen sensor...or at least that's what the mechanic said...
Old 03-11-2005, 12:46 PM
Update 2:
Well it died again brought it to the same guy. And then he said it was the ignition module..So there went 500 dollars for a days work(well...2 days work...)
Old 03-11-2005, 01:13 PM
wrightz28's Avatar
hmmm.
The second time it died, did it die the same way as the first (applying the brakes)?
Old 03-11-2005, 01:33 PM
LeBuick's Avatar
LeBuick LeBuick is offline
Too bad you didn't spend that thousand and bought a slightly better car...
Old 03-12-2005, 12:27 AM
Yea no doubt LeBuick, Well wrightz28 no it didn't when i hit the brake...it started then died right afterwards at Mcdonalds.
Old 03-12-2005, 05:28 PM
peshi03's Avatar
peshi03 peshi03 is offline
hey i have a 90 lesabre too and my blinkers just stopped but the hazards still worked, i had my turn signal switch replaced but it was like 200 bucks. i am selling my buick now with over 1700 i have put into it.
Old 03-12-2005, 06:33 PM
200 bucks..wow..you can do it yourself for about 50 bucks if its the turn indicator switch.
