2000 Rodeo Stalls When stopping
My 2000 rodeo stalls a lot, usually whenever i go to stop or am slowing down to pull into a parking stop. It idles a little rough, but rarely stalls when idling, just when driving through traffic lights for the most part. I brought it to a garage and they replaced the throttle valve assembly and the sparkplugs. The codes have been all checked and nothing could be found wrong. Any ideas?
Re: 2000 Rodeo Stalls When stopping
sounds like a classic leaking intake manafold gasket:
http://isuzufaq.ibctech.ca/#faq5 if you are the orginal owner Isuzu will replace it for free if you are under the 10yr/120k If you are the second owner they will replace it for 5yr/60k.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
The first thing i had done to the car was replacing the intake manafold gasket. Any other thoughts? thanks.
I wounder if they used the new torque spec of 13lbs.
Also, have you had your EGR and EGR port cleaned?
I have had the same problem for a while now also- the SUV will stall ocassionaly when idling or stoping, and also generally requires starting several times, it generally stalls after the first start.
I also had the intake manifold gasket replaced. It seemed to help a little bit, but now, two months later it is surely no better than before. [Please explain further about the new 13lb torque spec- what was the old spec?] I have no error codes. I tried cleaning the EGR and the EGR tube with carb cleaner. I suspected that the EGR was stuck closed, as it does seem to stick in that possition a bit. I don't know if the electric EGR (which has like 6 contacts) gives position feedback to the computer to tell if it is stuck closed and wether this would necessarily produce an error code. Anyway, I don't know what to do next. Rosemari, let me know what you find out. Anyone have any more ideas? |
have you done a general tune up?
