Old 03-02-2005, 11:39 PM
Emperorfirefox's Avatar
Emperorfirefox Emperorfirefox is offline
Send a message via MSN to Emperorfirefox
can you disable bumper signals?
Ok, heres the problem. I put a body kit on my 98 cavy awail back and the front bumper to this kit didn't have anywhere to put the bumper turn signals so i just stuff them somewhere behind the kit out of the way.
But then i get in a crash and the front bumper, along with the rest of the kit, disintegrate and tear out the turn signals with the sockets. (last time i buy fiberglass )
So now my left and right turn signal lights in my cluster stay one when ever my lights are on and when I do signal to turn my front and back turn signals blink hella fast. Really annoying
If anyone knows how to bypass the bumper signals to get rid of this annoyance it would be really helpful to me.
Old 03-03-2005, 08:13 AM
Tookie Tookie is offline
Not exactly an xprt on this but you could try two things. First assume the circuit errors out by detecting infinite resistance on the circuit indicating a blown bulb and makes the cluster indicate a failure like you described. So what you might do is check the resistance on a good bulb, and insert a resistor across each bulb circuit in the harness where the bulb/socket would normally be. That might fool the detection process into thinking the bulb still exists and is functioning ok.
Or; you could just pull that section of the harness into the trunk and use the lighting assy as a nice interior light for those times when you need it. You won't be bothered as long as the trunks closed when you don't need to be there.
Either way, you shouldn't need to go into the lighting system maintenance/reporting configuration doodads.
Just a guess from a newbie mind.
Tookie
Old 03-03-2005, 01:19 PM
Re: can you disable bumper signals?
The ideal with the resistors sounds good I think ill try that as for the trunk ideal that might be kinda hard to do and it wouldnt get rid of the fast blinking the lights on the hud.
Thanks tookie
Old 03-03-2005, 02:38 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Empty your blinker fluid resovoir.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-03-2005, 04:16 PM
noshun's Avatar
noshun noshun is offline
Re: Re: can you disable bumper signals?
yet again?!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 03-03-2005, 08:40 PM
I emptied the fluid like you said but didnt work and now the clutch feels weird???? oh well. . . . does anyone else have any ideals?
Old 03-03-2005, 08:46 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Re: Re: can you disable bumper signals?
oh my gosh, please tell me u didnt empty the clutch fluid resivoir
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-04-2005, 10:00 AM
Re: Re: Re: Re: can you disable bumper signals?
Old 03-04-2005, 10:05 AM
hummmm, weres the sarcastice emoticon..... lets see... nope, can't find it.
Does no one know how to disable these lights, i know its possible.
Old 03-04-2005, 10:43 AM
Lifted GMT-360!
ok ok... joke is old. But in all seriousness here is a link. I also have a how to for the 00-02 if anyone needs it.
http://www.teamforwardmotion.com/tfm...rl_disable.htm
Old 03-04-2005, 03:11 PM
pimpendacavi06 pimpendacavi06 is offline
how do u speed up the turn signal?
Old 03-04-2005, 03:44 PM
noshun's Avatar
use a different flasher unit!
Old 03-04-2005, 05:34 PM
Just BkMrkd the site. Def worth a read. Good catch Crj.
Tookie
Old 03-06-2005, 10:29 AM
Knifeblade Knifeblade is offline
Now, classic and noshun, play nice now, LMAO
Old 03-06-2005, 10:35 AM
Actually, outside of the cool site that CRJ gave, I've run a resistor across the leads for temp. fix.
However, operative is TEMPORARY!!!!!!!!!!!! Not really a recommended thing to do in any case for any reason. Except emer.fix just to get the car driving to home!!!!!!!!!!!!!!!!
