Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 03-02-2005, 10:41 PM
liam91ttz liam91ttz is offline
Send a message via AIM to liam91ttz
new stage 5 motor but having bugs, i need advice
i have a 91 300zxtt that has a stage 5 engine jut built, when i open up the throttle the turbos spool but when it hits 4 rpm turbos stop spooling when i hear the waste gate open up and i get knocking through my exaust and the car stops pulling and i have to back off. the only thing i can think of is i dont have the boost controler hooked up, but it is installed. any comments?
Old 03-03-2005, 12:20 PM
Hodo Hodo is offline
Re: new stage 5 motor but having bugs, i need advice
what octane are you running and is the boost controller working.
Finaly got pics of my car....... after I washed it of course.
Old 03-03-2005, 12:50 PM
probehtr300 probehtr300 is offline
this is what my car has been doin, i tried explaining it the best i could, but yeah it stops pulling and then u can hear a knock throuh the exaust, but my is n/a so it must be something seperate from your turbos
Past Z Car Crew
-josh
Old 03-03-2005, 02:51 PM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
first , not having your boost controller hooked up wouldnt cause that. and yes what octane are you running.check out your injectors and plugs ....
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
Old 03-03-2005, 03:57 PM
im runing 93 but the motor only has 500 miles on it, it starts to sputter when the waste gates open and wont pull from 4 rpm on
Old 03-03-2005, 04:36 PM
i got more of a serious problem i took it out and its fucked up with the same problems and in the drive i saw oil dripping on the drive way. time for the mechanic!!!!!
Old 03-03-2005, 08:09 PM
well mine isnt leacking, and is a nonturbo but is doin the exact same thing, so when u find out whats wrong please share
im runnn 93 oct. im not stupid, and i already changed my plugs hoping that would solve the problem but it didnt help, it could be injectors ??? hmmm
Past Z Car Crew
-josh
Old 03-03-2005, 08:16 PM
what im worried about is that terorous knocking through my brand new turbo back hks exaust!
Old 03-03-2005, 09:12 PM
telling you its probly the fuel your running what octane you running in the car and what timing setup are you tring at what boost levels. To high of boost with too far advanced timeing on the wrong octane = knocking aka big trouble. If you have oil now dripping from under your car you probly did some damage to either a turbo oil line or to your oil pan gasket with blow by..... you hope its blow by and not blow through from running the wrong octane fuel in your car. Either way sounds bad and your not going to get much help from us without any of the basic info we ask for.
Old 03-03-2005, 09:36 PM
im running 93 oct on stock boost which is 10psi, as far a timing goes i dont have the tools to check it, but i think the leak has more to do with the hicas but well see tomorrow when i get it in the air.
91 300zx twin turbo stage 5
[B.] Past Z Car Crew [/B.]
Old 03-04-2005, 11:58 AM
Your Hicas could be causeing the issue. Or be part of the problem, not the cause. If you eliminate all the other variables it could very well be the simplist things. I will wait to see what it is, now I am interested in seeing if its the HICAS.
Old 03-04-2005, 05:18 PM
there was a leak coming right from the power stearing resovair which i fixed and i hope it will stop something but the car has a hicas eliminator which shutts off the 4 wheel stearing to just the front wheels. i saw oil coating the tranny n its comming from the front of it. i have the turbo intake tubes off and they were dirty inside, might be oil, but the motor is fresh, i maybe have a oil leak with the turbos.
Old 03-04-2005, 05:27 PM
ive narrowed it down to a bad gasket on the oil pan or oil line to the turbos, im gona get second opinion on it when when i find someone who lives near me n knows how to work on the z32. the only other wierd thing it does it not shift great into second from first, but thats probably a clutch alignment thing.
Old 03-04-2005, 05:57 PM
Could be a rear main seal. Or like you said a oil pan gasket or turbo line leaking. But it still sounds like you have many more problems than oil leak I would start to wonder about this engine or the install of it.
Old 03-04-2005, 06:17 PM
the bottom half was rebuilt in nov and sat untill i started driving it, i think all it needs is for me to learn how to fix it( i just got it a month ago, and am picking alot of things up about it with no prior skills on the z32. ) im new to autoformum, but have figured it out in like two days, i wish i could be more of help to my situation, but right now i dont know enough. it hasnt been runing crappy and drives fine, its was just when i tried to open it up for the 1st time is when the knocking in the exuast happened leading to the problems i have now, its gonna sit till im sure im not going to hurt it more.
