Old 03-02-2005, 11:29 PM
EVCeltic116 EVCeltic116 is offline
94 LX won't start
I have a '94 LX 2DR Escort and the other day when I tried to start it after school it wouldn't start. This was after a good 8 hours of sitting in the parking lot. Anyways, a loud clicking sound comes from the engine. The battery is fine and I have power to everything. I can push start my car and have had to do it a few times (I'm sick of it too). A friend of mine and I tried to take out the starter to see if that was the problem but we couldn't even get the thing to come out. Any help would be greatly appreciated.
Old 03-03-2005, 07:37 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: 94 LX won't start
have you checked the basics? like wire connections? how do you know your battery is fine? have you check the ignition solenoid?
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 03-03-2005, 11:06 AM
A. Souphound A. Souphound is offline
If the clicking sound begins when you try to start the vehicle, it may be a broken or damaged starter drive.
If you have all of the bolts removed from the starter it should come out. Check to see you have all of the bolts removed....the one between the starter and engine block is hard to see...
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 03-05-2005, 11:19 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
try the good ol' "turn on the headlights and crank the engine" test.
It is possible to have voltage in the battery to run the radio and accessories, but not enough amps to turn the starter.
If the headlights die out when you crank it, replace the battery. If they stay bright, look at the starter relay or the starter itsself.
Old 03-06-2005, 12:54 AM
TheStang00's Avatar
TheStang00 TheStang00 is offline
try this, it works. u said u didnt get the starter out... get a hammer and whack it a few times... not kidding, and then try starting the car. what happens is the brushes inside the starter get all pushed over after a while and whacking it like that can jolt then and loosen them up. this will only work a couple times tho... if the starter is bad then u have to replace it.
Old 03-07-2005, 12:54 AM
Hey thanks a lot everyone. MightyMoose was right. it was the battery. I just needed to charge it and everything is fine now.
