Old 03-02-2005, 10:22 PM
Redfish Hooker Redfish Hooker is offline
Unhappy 2000 ck3500 eletrical trouble
12/22/04 My lights got dim and volt gauge went down to about 10 volts and less tested the alternator was good right at 14 volts put on new battery volt meter went up to 14 all was good till about 2/25/05 all started over then one night every thing went dead lights motor eveything dead pulled alternator had it checked 14 volt again tried to jump truck off no luck went and got new battery truck cranked right up drove it about 6 miles to and from work volt meter went to about 10 volts battery light on please help. thank you i'am new here
Old 03-02-2005, 11:40 PM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: 2000 ck3500 eletrical trouble
Have you checked your battery terminal connections. If they are of the stacked positive terminal design, you need to make sure that they are absolutely clean and free of any corrosion. If the alternator checks good and the battery checks good, the only thing left is the connections between the two. Have you also checked your fuses in your underhood box? If you originally replaced the factory delco battery and it was leaking acid, the terminals could have corrosion between the stacked positive terminals.
Old 03-03-2005, 11:00 PM
amac209 amac209 is offline
Send a message via MSN to amac209
checking an alternator with just a volt meter doesn't give the whole story. if a diode is burnt the alternator will dump ac voltage into the battery and suck juce out of the battery when you shut it off. some shops/ parts stores will test your alternator for free.
Old 03-07-2005, 12:16 AM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
check the remote positive terminal in the lil red case to the left of the motor, make sure connection is good, i had same prob, i replaced the stud with a grade 8 bolt and nut, and used dielectric grease for a better connection...dont forget to wrap it all with some type of insulation, ie elec tape
