2 or 3" lift, cost, difficulty,
hey i was just wondering how much it costs to put a 2 or 3" lift on a 98 4x4. i also would like to know how difficult this is, and the parts that would need to be replaced or modified. i've never done a lift before and i don't even know the first thing about one, but i look on cardomain.com and almsot every ranger there has at least a 2 inch lift. also if someone could reccomend tires. i want something that looks good with the lift and won't be bad for some light offroading, but would also be good on the highway and around town. thanks in advance, and please feel free to leave any other information you think i might find useful.
Re: 2 or 3
so here's the deal-
Performance Accessories make a 3" body lift - which just lifts the body higher off of the chassis - for like $180. This still makes clearance for bigger tires and gives that cool look - good for people like you and me who mostly stay of the highway - leaves the suspension 100% stock Homemade 2" suspension lift - this is what 'eveybody has' on cardomain. For the rear, they put in an add-a-leaf kit - which is a new leaf spring to through in the pack and a new center pin - from companies like Rough Country and BDS and Fabtech - cost about $40. these will stiffen the ride a little and lift 1.5" - 2". For the front, they crank the torsion bars - this is free EXCEPT for the wheel alignment that you MUST do afterwards which may cost as much as $150 since they may have to put in new camber kit. - Even so, $200 for a 2" lift is very reasonable. Things to consider... Stock - go with 31x10.5 tires, stock rims good- gears ok, speedo reads 3mph slow 3" body lift - go with 33x12.5 - needs new rims (wider), new gears (unless you are ok to go a little slow and already have 4.10), and you're speedo will be off a good bit - should get new speedo gear 2" Homemade - 32x11.5 - stock rims OK, but wider suggested - gear change is up to personal discretion, and same with speedo change
If it moves and it shouldn't, use duct tape. If it doesn't move and it should, use WD40. |
Re: 2 or 3" lift, cost, difficulty,
a 3" body lift is fairly simple to install and will give you clearance for some 33" tires. the kit from performance acc comes with very detailed instructions.i added a jet chip, k&n filter & a gibson exhaust and have about the same power as it had before the bigger tires. BFGoodrich mud terrains work pretty well on or off road.
thanks guys, i haven't decided on actually buying a ranger yet, but i wanted this info becasue if i did it would definatly have to be lifted. i may look into the new 150's since working for a dealership i can get huge discounts on new vehicles. thanks again
