Old 03-02-2005, 09:38 PM
polock169 polock169 is offline
Send a message via MSN to polock169
Question "limp mode"
this limp mode is a bunch of crap. What I want to know is if there is a sensor that says something is wrong.....and puts it in limp mode...........is there a way to bypass that sensor to get the rest of the life out of the tranny. it goes "LIMP" but is there any type of temperary viagra for it????
Old 03-03-2005, 03:02 AM
SteveB05's Avatar
SteveB05 SteveB05 is offline
First, please delete your double post.
There are a lot of sensors that inform the control modules of system status...many of which can cause the programming to go into a limp or baseline mode. Specifically, it sounds like you are speaking of the PCM (powertrain control module)...is the transmission stuck in 2nd gear?
You can try disconnecting the battery for a few minutes to reset the computers. If there is a problem though, it will go right back into "limp" mode. Plus this can cause other temporary drivability issues (start - die, rough idle, etc).
Steve
'98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s.
Old 03-05-2005, 11:08 PM
android606 android606 is offline
There are a whole laundry list of conditions that can cause the TCM to go into limp mode. You may not need any "Viagra", you might just need a new speed sensor, or the connector on the solenoid pack could be loose, dirty or broken.
One thing is for certain; if you keep driving it that way, you'll burn it up. A $35 speed sensor problem can cause a $2200 transmission overhaul problem pretty quickly.
The only way to find out is to pull the codes from the computer and find out why the heck it's limping.
Andrew Mark
http://www.rivercitytransmission.com/
