Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-02-2005, 09:30 PM
JohnWallace JohnWallace is offline
Question Replacing Front Drive axle
I have a 95.5 rodeo V6 auto 4wheel Drive. The passenger side outside boot is ripped. I picked up a rebuilt axle and was going to have it replaced by my local mechanic. He has my Haynes manual, but needed clairfication on removal. He called the Izusu dealer and was told that you can only use Original equipment axles. Anybody heard of this? Can we just replace the outside boot...do they make a two piece boot so we don't have to remove the Axle? Please
Old 03-02-2005, 09:46 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Replacing Front Drive axle
http://www.4x4wire.com/isuzu/tech/CVboots/?
I don't know if this will help.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-02-2005, 10:15 PM
Cat Fuzz Cat Fuzz is offline
If you havn't had it in 4wd much and its not shift-on-the-fly you should be able to just replace the boot. Split boots are crap.
The trick to removing the shaft is you must seperate both the upper and lower ball joints to have enough room to get it out. Also, on the inner joint, the outside housing for the inner joint stays in the truck. There is a retaining ring around the inside of the cup you have to remove. To get to it, you ned to remove the inner boot. What I did was carefully cut the clamps and pull it away from the joint and just got a couple extra clamps to reinstall the old inner boot. Or you could just replace the inner boot while its out, but the inner boot doesn't see nearly as much stress as the outer.
Old 03-04-2005, 02:06 PM
witherer witherer is offline
Use the article provided by amigo-2k. I had the same problem, and it walked me through it with ease.
