Old 03-02-2005, 08:32 PM
cyclonez cyclonez is offline
99 trunk release not working
a month or so ago the car's trunk release stopped working. When you press the button you hear the relay click, but the trunk release doesn't pop. You can still manually open the trunk with a key.
I'm thinking about checking this out with a volt-ohm meter at the trunk while my GF presses the button. Has anyone else had this problem, and can you offer any suggestions as to what it might be?
Thanks,
Chris
Old 03-02-2005, 09:14 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: 99 trunk release not working
Thanks,
Chris
WD 40 may be your best friend with this problem.
I wonder if you can add a keychain trunk pop release to a car that dont have the remote part though
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 03-03-2005, 10:40 AM
A. Souphound A. Souphound is offline
Thanks,
Chris
Sounds like you have a good troubleshooting strategy...(had it been a door lock and I heard the 'click' the solonoid would be my prime suspect.) Of course lubrication as chevy0va1 suggested may be the answer....
Good luck,
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 03-03-2005, 10:58 PM
I got my light out and started looking for a place that I could disconnect the wires and plug in my volt-ohm meter, and then I noticed the wires were broken! Apparently just from wear and tear. But all I need to do, it seems, is splice in some new wire and it's good to go!
Old 03-04-2005, 06:36 AM
Thanks for the feedback.
Another thought: Add some shrink sleeving on the wires in the highly stressed area to prevent a recurrence.
All the best,
Alvin
Old 03-04-2005, 02:38 PM
chevyn0va1's Avatar
Re: Re: 99 trunk release not working
All the best,
great tip as always
