Old 03-02-2005, 08:18 PM
Tey_Marzetti Tey_Marzetti is offline
Send a message via MSN to Tey_Marzetti
91 S-10 Heater
If you don't turn the heat on, get it on the freeway and let it warm up, it's fine.
Can't get any heat when driving in town because the heater fuse keeps blowing.
Any suggestions?
Old 03-02-2005, 09:12 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 91 S-10 Heater
Is the fuse the correct amperage? Should say in the owners manual, mine is a 20A. Did you wire anything on that's using power from the blower circuit? Does it blow with the fan on low? If it does, it's probably a problem with the fan motor. Remove the electrical connector from the motor and turn the switch on. If the fuse doesn't blow, the problem is not the motor. If it does blow, you've probably got a shorted wire between the switch and the resistors in the blower plenum.
If it doesn't blow with the fan disconnected, hook power up to the fan with jumper leads. Leave them on just long enough to see if the motor starts or not. If it doesn't turn, replace the motor.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
