Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-02-2005, 07:32 PM
Thomas15 Thomas15 is offline
1995 contour will not start
The car continues to try to start but doesn't. The last two days I would have to try a couple of times before it started and today nothing. The problem seemed to be only in the mornings or after the car sat for a few hours and was cold. The car ran fine after it started except for the check engine light came on, been doing that for last 15,000 miles and numerous trips to mechanic. Full tune-up at 100k, now has 109k (fuel filter, plugs, wires, oxygen sensor, pcv). Any ideas, maybe a fuel pumpor a sensor, I checked the reset button for the fuel pump and it is OK. I need to get it started so I do not have to tow it to a garage.
Old 03-02-2005, 07:49 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
could be a crank position sensor.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-02-2005, 08:08 PM
Re: 1995 contour will not start
Would the MAF cause the car to crank but not start. The engine is a 2.5L v6.
Old 03-02-2005, 09:24 PM
It could, but its highly unlikely. Unplug the MAF and see if it starts. If it doesnt, then it eliminates that possibility.
Is it an auto or 5 spd?
"The CEG Nazi"
www.contour.org
Old 03-02-2005, 10:30 PM
I am getting spark but I am not sure about where to check if fuel is getting to the engine. Where is a good place to check the fuel line?
Old 03-02-2005, 11:17 PM
Check the fuel pressure valve.
To the right of the pink cap, theres a little black bleeder valve. Unscrew the cap, and push down the valve with a nail or something. Make sure the key is in and the car is in accessory so that the fuel pump is on. The bleeder valve is located underneath the throttle body.
"The CEG Nazi"
www.contour.org
Old 03-03-2005, 12:06 AM
I am getting fuel to the valve, the only thing I do not know how to check is the crank position sensor. Is there a way to check it? Thanks for your help. (so far)
Old 03-03-2005, 12:35 AM
Im not sure if their is any real way to monitor the cps. Maybe a voltmeter?? It should be a cheap easy fix.
One more thing! Inspect your wiring harness for your fuel injectors. The 95-97 models had a recall on all the wiring harnesses being known to crack and become exposed. Theres a 10 year/100,000 mile warranty on this recall. Your injector harness may have become exposed and could be arching, causing the injectors to be running full duty.
Its located right above the AC compressor and its held in by one bolt.
"The CEG Nazi"
www.contour.org
Old 03-03-2005, 01:11 AM
I just finished checking the crank shaft senor with the meter and there was no reading. In the morning, I will go to auto store for its replacement. Hopefully this will resolve the issue. Again, thanks for your help.
Old 03-03-2005, 11:44 AM
New Crank Shaft Sensor did not fix the problem. Any other ideas?
Old 03-03-2005, 12:10 PM
have you inspected the wires under the upper intake manifold yet? Your injector wires may be exposed.
"The CEG Nazi"
www.contour.org
Old 03-03-2005, 12:50 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Spray a little carburetor cleaner into the throttle body. If it starts, it is a fuel delivery problem. If it has spark, the crank sensor was good. Ford is known for bad idle speed control motors. If it is stuck closed, there is no air flow into engine, therefore no start. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-03-2005, 01:23 PM
Thanks for the info, I finally had the car towed to a mechanic to see what they can do. I will update what the problem is.
Old 03-03-2005, 11:55 PM
Mechanic thinks it is the ECM. The cooling fans run when switch is turned on and the fuel pump is no longer working. I will update tomorrow.
Old 03-10-2005, 11:41 PM
Finally got the car out of the shop. New fuel pump $250, new ECM $250, new ignition module $250, new wiring under manifold $130, replaced belts $free, labor and wiring troubleshooting $600. Total spent on car is about $1500 so far. Car going back into shop to see why check engine light still on. Other than the light car runs great and is FOR SALE!!
