Old 03-02-2005, 06:21 PM
Meandean Meandean is offline
Unhappy I need help!Cant get rear disc off blazer
I am trying to repalce the rear disc on my Blazer but I cant get the disc unit off.I replace don side with no trouble but this one just wont budge.
Do I need a gear type puller of some sort or can I heat it up with a
small torch,etc.
Old 03-02-2005, 06:25 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: I need help!Cant get rear disc off blazer
You did remove the center nut right?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-02-2005, 06:27 PM
Re: Re: I need help!Cant get rear disc off blazer
There is no center nut on my 2000 blazer in the rear.
Old 03-02-2005, 06:32 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: I need help!Cant get rear disc off blazer
Then how is the disc held in place?
Old 03-02-2005, 06:35 PM
Re: Re: Re: Re: I need help!Cant get rear disc off blazer
The rear disc is on one piece type hub.There is a parking brake in the
hub assembly.The other side,which came off,I just pulled on it a few
times and the assembly comes off.
Old 03-02-2005, 07:17 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
I had this problem on my rear... The horseshoe slipped in side the rotor and it just took a lot of prying to get it off...(No damage to the horseshoe)
Old 03-02-2005, 07:19 PM
rlith's Avatar
Just like the front...
And what probably happened as I described above, is one of these probably slipped...These are the emergency brake shoes that reside inside the drum portion of the rotor.
Old 03-02-2005, 07:37 PM
Re: Re: Re: Re: Re: I need help!Cant get rear disc off blazer
thats what it looks like.I will kepp trying to pry it off.Thanks]
Old 03-02-2005, 07:44 PM
rlith's Avatar
You might have to smack it with a hammer too (I did)...
Old 03-02-2005, 09:15 PM
well at last it came off!It was frozen on the inner drum.
One big problem,the upper clip that holds the upper shoe
broke.Can I do without the clip ?
Old 03-03-2005, 05:03 AM
ricksza's Avatar
ricksza ricksza is offline
Are you talking about the clip that holds the parking brake shoe? If so, you need this to hold the shoe in place or it will twist inside the drum. If your talking about the clips on the disc pads, they are they to prevent noise and without them, the stands will wear out.
Old 03-03-2005, 05:20 AM
rlith's Avatar
I think he's talking about the clip for the horseshoe.... You can get that from the dealer for a buck a clip... DO NOT USE A SCREWDRIVER on the screw that holds it in, use a 7mm socket...
Old 03-03-2005, 08:21 PM
yes the horse shoe clip.Went to 2 chevey dealers,and get this,
that clip cost me 33.00 DOLLARS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Why? You have to buy a new horse shoe to get it!
What a total rip off.
Old 03-03-2005, 09:34 PM
rlith's Avatar
well the horse shoes come in pairs, so not a total ripoff...You could always pull one from a wreck..
