Old 03-02-2005, 06:13 PM
mus5.0tang mus5.0tang is offline
Send a message via AIM to mus5.0tang
hatch door problems
the hatch door on my 88 gt is rattling when i go over bumps. im thinking it could be the bushing on the latch. whats everyone else think?
Old 03-02-2005, 06:59 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
Re: hatch door problems
i had the same problem and it turned out to be the hatch hinge was shot. the little plastic bushings were gone on the hinge.
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 03-02-2005, 07:14 PM
where can i find a new bushing.. and how much do they cost
Old 03-02-2005, 07:37 PM
i bought a new hinge, it was about 60 bucks at a ford dealership but u may find one on ebay for less or try any of these sites. www.mustangsunlimited.com, www.texasmustang.com,www.yearone.com
Old 03-02-2005, 10:43 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
The bushing is the first thing to check, like stated. I also had a problem with my old GT where the hatch was not lined up properly, and I have to un-do the bolts and re-align the hatch.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-03-2005, 12:33 PM
1993_GT 1993_GT is offline
Check your hatch striker, I had the same problem with my hatch rattling on my 93 GT. Replaced the striker and all is well. Got the strike at Discount Auto for $12.00.
Old 03-07-2005, 10:49 AM
i just replaced the stricker and the rubber bumbers on the sides. the ratteling is still there. to realign the top do you have to undo all the bolts.
Old 03-07-2005, 09:00 PM
HiFlow5 0's Avatar
Stanger
once you take the access panel off from the roof, there are to bolts to loosen, thats it.
-2013 Ford Flex
-1999 Ford F150
