Old 03-02-2005, 04:52 PM
Heather_Ryan's Avatar
Heather_Ryan Heather_Ryan is offline
Unhappy 402 BB Oil Pressure problem-none
I have a chevy 402 that has no oil pressure. The crankcase is full of oil. I pulled the oil pressure line fitting off and turned the motor over a few times with the starter and got no oil out of the block. Is the oil pump fried? I need help troubleshooting fast because I need to fix before I leave to Iraq in a week. Please help.
Old 03-02-2005, 05:02 PM
testtube's Avatar
testtube testtube is offline
Im no mechanic, but a long time ago I had a bronco that suddenly dropped the oil pres. We dropped the oil pan and the oil pump had actually slid down somehow and the shaft wasn't engaging it.
damn fords
P.S. Good luck in Iraq
Old 03-02-2005, 05:04 PM
5150cavy 5150cavy is offline
Send a message via AIM to 5150cavy
If you pulled the fitting and had no oil when you turned it over by the starter more than likely you got a fried oil pump. You can pull the distributor and try priming it with a flat bladed screw driver and turn it clock wise you should get oil up in about 3-4 turns. If you still get no oil pressure then the pump is shoot. Hope this helps some.
You can check out my ride and my crew at http://www.twistedperfektionz.com
UNDER CONSTRUCTION
Old 03-02-2005, 05:05 PM
Re: 402 BB Oil Pressure problem-none
thanks. Thats a good posibility. I guess I will have to lift the motor and pull the oil pan.
Old 03-02-2005, 05:08 PM
Thanks, that will be the next step to testing
Old 03-02-2005, 05:53 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Ugg, get rid of that cover on the carb... Let that damn thing breathe
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 03-02-2005, 06:02 PM
Trust me, that cover was just on while I was workinking on it. It breathes through a 14"x2" air cleaner.
Old 03-03-2005, 03:25 PM
bad68chev bad68chev is offline
Re: Re: 402 BB Oil Pressure problem-none
Was the motor rebuilt? I know on small blocks there is a plug you have to install under the rear main bearing cap, if its not installed you will have no oil pressure. Not sure if big block has same plug or not (thinking it does)
Old 03-03-2005, 03:26 PM
Re: Re: Re: 402 BB Oil Pressure problem-none
Also check clearance between oil pump pickup and bottom of pan.
