Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-02-2005, 04:33 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
speedo cable
Ok i was thinking today and this just popped up. 88-91 civics and CRXs Have a cable running from the trans to the gauge cluster for your speedo reading right? But the newer civics and del sols (92 and up) don't. They use an electrical signal for the speedo reading right? if this is so, how would you get your speedo working if you were to put an engine and trans from say a 99-00 civic SI or del sol VTEC into an 88-91 model? Any help? Maybe i am wrong.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 03-02-2005, 04:45 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: speedo cable
I think for the 4th gen civics they use a cable B16 tranny, JDM ofcoarse. Maybe there is another way though.
Old 03-02-2005, 05:08 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: speedo cable
vss's are interchangeable so just stick your stock cable vss into the hydro trans, if you are using a hydro trans
Team Lonely Drivers
Old 03-02-2005, 06:05 PM
Re: speedo cable
so 92-95 civic models use a speedo cable to too then? Or would you just remove the sensor that was used in the hydro tranny (92-95) and put the cable in its place from the 88-91.
Old 03-02-2005, 06:34 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: speedo cable
why would you want to swap an older engine into a newer car?? isnt that illegal??
Old 03-02-2005, 07:14 PM
Re: speedo cable
hes talking about a 99-00 si motor into a 4th gen. thats newer motor into older car.
im pretty sure from 92 and up its an electronic vss. so if you want to run your cable speedometer then you need to put your stock cable vss into the newer tranny. or if you want to run an electronic speedometer then you need to switch to a electronic vss, if your stock was a cable. there all interchangable within the trannys so just get whatever matches your speedometer
Team Lonely Drivers
Old 03-02-2005, 07:22 PM
Kind of a Big Deal
Re: speedo cable
ahh.. oops mustve read it wrong... ignore me.
Old 03-02-2005, 10:06 PM
Re: speedo cable
Gotcha, thanks for clearing that up.
