Is there More than one fuse box in a 91 in this OLd's silhouette?
Ive check them all but it trys to turn over but it wont turn it dose the kick up but not the kick over? Was told it might be a fuse box is checked i see none blown but i also got told there is more than one fuse box? If anyone can help i would greatly appreciate it Thanks
Re: Fuse Boxs
Hello,Did you check under the hood? some fuse boxes are located there. Also look on the rightside (passenger side) kick panel(Below the glove box).Also may want to check for spark at the plugs,And fuel pump pressure.Have a good day..Diesel 1962...
Re: Fuse Boxs
I have jeep grand cherokee 2001. I am trying to install some after market signal arrows to the mirrors. it has a negative and positive wire instructions tell me to connect pos. wire to the signal fuse, looking for wire under steering counsle. can someone help me out with this. thanks.
Re: Fuse Boxs
mommy,
Fuse/relay box under the hood is right over top the battery. Passenger side.
The problem with doing nothing is not knowing when you're finished. |
