Old 03-02-2005, 04:45 PM
fief fief is offline
Huge Electrical Problem Please Help I'm Desperate!!
hey every one i'm new to the forum , pleaseure to meet you all , i do need some help or suggestions tho , i have a 1992 pontiac grand am 2.3L 4 cyl quad 4 and i'm having a major electrical problem , now my left turn signal goes on but doesnt flash the right signal works but it is not the bulb but it is more difficult than just the turn signal when i step on the brake 1 out of 3 of the brake lights work and i hear a clicking sound which sounds like my power locks and the little seatbelt warning light comes on and the little light that tells you which gear your in goes off also when i step on the brake any ideas the lights go back to normal when i let go of the brake the lights go back to normal any suggestions??? thanks alot ^_^
Old 03-02-2005, 05:02 PM
Knifeblade Knifeblade is offline
Re: Huge Electrical Problem Please Help I'm Desperate!!
Start with your flasher for the signals. Location is behind instrument panel, on L side of the steering column bracket.
Then check the turn signal relay, a black box with around 4-5 prongs. This is usually located under the dash, passenger side, and is one of several relays in their own small electrical box.
Your owner manual should point out where the relay is.
