Old 03-02-2005, 12:13 PM
Gaston1971 Gaston1971 is offline
Question Intermitent start problem CAravan 96
Hi everyone
I have a mysterius problem with my van.
I changed batery, started, distributor, rotor and alternator but anytime my van won't start....i wait 1 hour, maybe 2 hours and then it star normally....the electricien can't find the problem...anyone can helpme please..!
Thanks in advance
Old 03-02-2005, 10:01 PM
yogi_123rd yogi_123rd is offline
Re: Intermitent start problem CAravan 96
By car won't start, does the engine turn over, is there just a clicking noise when you turn the key, or nothing happens when you turn the key?
Is engine size 3.0 or 3.3, or 2.5 liter? The problem sounds intermittant. Based on a better description, it sounds like it could be with the starter or an ignition sensor.
Old 03-03-2005, 09:29 AM
Re: Re: Intermitent start problem CAravan 96
HI thanks for your answer..
Look nothing happens, no sound but i have energy because i can turnoff the radio, the ligths etc.. but no sound, no click...and after maybe 2 hours, i can star without problem...yesterday i changed the start's relay..and i'll wait...
You talk to the ignition sensor where could i find it?
Thanks you again.
Old 03-03-2005, 11:29 AM
Hmmm???? Try wiggling the key after putting it in the ignition barrel. Problem could be in the ignition switch.
Old 03-03-2005, 11:30 AM
HiRez_L HiRez_L is offline
Or the neutral start switch.
Old 03-03-2005, 02:52 PM
aha....i put the key, turn on and wiggling the key in the on position...ok
i'll try.
The same happen with i try to start it with my remote starter
Thanks !
Old 03-03-2005, 02:59 PM
Hi Hirez
Look, when it happened i try to start in neutral position and in parking position...but no start...the specialist say me 'when the problem come again he could find it', but only when the van doesn't start..so i'll pray for that the problem stay until the specialist comes...it's crazy.
If i find the solution i'll say you
Thank you very much.
Old 03-07-2005, 12:02 PM
Hi again
I was the same problem this week end, i tryed to start wiggling the ket but nothing...i don't know...
Thanks for the advise.
