Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-02-2005, 08:22 AM
jimmy4x4 jimmy4x4 is offline
throttle cable
how to install i checked my haynes but it doesn't tell me how only how to check for problems
this is the cable that does from the throttle to the foot pedal just in case i am calling it by the wrong name
also my headlights and heater are acting wierd they fluctuate my headlights dim and brighten while my heater blows out slow then fats anybody know why
Old 03-02-2005, 01:43 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: throttle cable
Look up "accelerator cable" in the back of your Haynes book. Mine has it in there, but it is a different year.
Old 03-03-2005, 09:36 AM
Re: throttle cable
about the head lights and heater i forgot to mention the volt meter drops as well any ideas
Old 03-03-2005, 10:24 AM
blazee's Avatar
Problem?
Re: throttle cable
Will they straighten out if you press the accellerator a little? Have you checked all the connections at the battery and alternator? Make sure the belt isn't slipping, if everything checks out I would lean towards a bad alternator.
Old 03-03-2005, 11:30 AM
smonaldo smonaldo is offline
Re: throttle cable
as far as the surging electrically, I have seen a bad alternator cause the problems you describe, sort of a cause and effect situation. On some vehicles, a bad alternator even causes problems with the electronic fuel injection system
Old 03-03-2005, 08:38 PM
Re: throttle cable
well i know that the belt to the power steering is slipping or at least i can feel the seering wheel tighten up and then release could these be related?
Old 03-04-2005, 06:27 AM
from what you describe, it sound like a loose/bad serpentine belt....it should take about 10 minutes to put a new one, unless the probelm is mechanical. perhaps a bad tensioner
Old 03-04-2005, 07:28 AM
Re: throttle cable
i think i will have autozone check my alternator and go from there thanks guys
i'll be back my jimmy is disease ridden
