Old 03-02-2005, 02:46 AM
mbrownab mbrownab is offline
Signal Lights
If anyone can help, It would be much appreciated...
With my signal's, I have a '93 Grand Am SE and whenever it is a little cold, the blinkes wont work. It makes a little noise and they just shut off.... any Ideas?? TY Im advance
Old 03-02-2005, 08:32 AM
Hoags's Avatar
Hoags Hoags is offline
Re: Signal Lights
It sounds like a bad flasher relay, I would look at replacing that. It is usually located on the fuse block, but I'm not sure on the 93.
Old 03-03-2005, 07:54 AM
Knifeblade Knifeblade is offline
Re: Signal Lights
Most likely the flasher, a roundsort of grey/silver can will be found under the instrument panel to the L of the steering column bracket. It very tucked away, so get a flashlight and prepare to bend your body in unnatural positions to get under the steering column enough to look around the firewall.
Old 03-03-2005, 11:46 AM
re: signal lights
The 4 ways work very good, but u think its still the flasher??
Old 03-04-2005, 06:28 PM
Re: Signal Lights
Yeah, I'd still try to replace the flasher can. I may be wrong, but I think the 4-ways operate independently of the turn-signal flasher. If nothing else, a new flasher isn't much, 2-3$
Old 03-04-2005, 06:30 PM
Re: Signal Lights
One slight possible, is to replace the turn signal fuse, but I rather doubt that is the problem. Do the turn signal bulbs [outside of the car] turn on at least when you hit the turn signal lever?
Old 03-05-2005, 02:16 AM
Re: Re: Signal Lights
Well when my blinkers work, they flash and all, But when they dont
NOTHING lights up, (outside or in) Like I said , It makes a weird little sound and , nothing!!. I bought a flasher tonight will try it in the morning!! I will let you know what happens....ok?
Old 03-05-2005, 06:26 PM
Re: Signal Lights
Np, hope it works
