Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-02-2005, 01:57 AM
TheFugitiveMind TheFugitiveMind is offline
drain and refill coolant
im planning to flush my coolant system. how do i locate the drain plug for the radiator? and what are if any special precautions i should take? its a 2001 passport with 50k miles
thanks!!!!!!!!!!!!!!!!!!!!
Old 03-02-2005, 07:54 AM
steveb_92rodeo steveb_92rodeo is offline
Re: drain and refill coolant
The drain will be on the bottom of the rad, probably toward the engine (if it has one or not).
I always find it easier just to pop off the lower rad hose instead of fumbling with the drain.
Steve
Old 03-02-2005, 08:23 AM
superfret78 superfret78 is offline
I don't know how the 2001 is, but on my 1994 the drain plug is very hard to get to because of its location. I really can't even see mine from the top or the bottom of the vehicle. Like Steve said...its easier to just remove the lower radiator hose a lot of times. It will drain faster too....just watch out for that initial splooooooosh! When you refill it, use a 50/50 mix of coolant and water unless you live in a really cold climate, in which case you could go 60% coolant and 40% water. AS for precautions to take...well it should be obvious, but don't do this job unless the car is completely cool or you'll get burned. Since you're draining the radiator, now would be an opportune time to replace the radiator hoses if they're old. Check for cracks, pitting, swelling near the ends where they connect, etc....all these things are signs that the hoses need replacing.
Old 03-02-2005, 08:46 AM
amigo-2k amigo-2k is offline
Isuzu Guy
http://isuzufaq.ibctech.ca/#faq66
I'm missing the link in the faq's
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-02-2005, 01:15 PM
you guys are awesome! thanks for the quick replys
what should i use to catch the fluid?
Old 03-02-2005, 01:44 PM
Re: Re: drain and refill coolant
You can buy an anti-freeze bin from any parts dealer, or a very large bowl, a windshield fluid bucket cut in half etc, etc.
Ususally, I would use a large (very large) bowl, and when it gets near full, put the bottom rad hose back on, dump the bowl full of old AF through a funnel back into a container (washer fluid, or old AF bottle), then wash, rinse and repeat as neccisary.
Steve
Old 03-02-2005, 10:57 PM
SOLSTER SOLSTER is offline
I did a pretty thorough thread on how I approached the flush:
http://www.automotiveforums.com/vbul...d.php?t=317539
I didn't flush based on advice it could dislodge cr*p and actully start leaks.
I didn't pull the enginge drain plug, wasn't necessary with the method I did, and I read it could be a PITA to get to.
I did six set of drains, refilling each time with distilled water (all in the thread), the first drain the fluid was very hot, I drained it using a funnel into 2.5 gallon water bottle - I was afraid it would melt through - so I out outdoor plant drain pan under the water bottle. after the first drain, I was able to drain the other 5 times directly into 1 gallon water bottles using a funnel. The six flushes cleared the radiator system very well of the old fluid, I then filled with 100% prestone, which mixed with the remaining fluid in the engine to get a 50-50 mix, which I tested with a fluid tester.
All in all, a very clean method, and good for the environment (relative to a flush using a hose). And I'm confident of the results!
Jiffy lube took my fluid for recycling for free.
Hope that helps. read the thread, lots of good info!
SOLSTER
1999 Isuzu Rodeo S 3.2L, 4x4, Auto, Great Truck!
2007 Pontiac Solstice GXP, Aggressive Red
Old 03-02-2005, 11:00 PM
Steve
This is true for first gen rodeo's, the second gen have a very convenient stop cock at the bottom of the radiator, it has a screw action that loosens to drain, do not remove, just loosen. Easy to get to - and easy to put a funnel under. Feel sorry for those 1st gens for this reason, but they have less oil consumption issues, so it's even
SOLSTER
Old 03-03-2005, 01:07 AM
Ramblin Fever Ramblin Fever is offline
Re: Re: Re: drain and refill coolant
SOLSTER
Yep! Na-na-na boo boo!! Hehe! No oil consumption here; (knock on wood)
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 03-03-2005, 08:45 AM
Re: Re: Re: Re: drain and refill coolant
LMAO
I'm in the same boat here too...yeah! (knocking on wood of course).
Steve
Old 03-03-2005, 11:58 PM
df2000 df2000 is offline
Send a message via AIM to df2000 Send a message via Yahoo to df2000
I never can reach rad drain plug front crossmember on the way.
I disconect lower rad hose, it get about 4q out.
But there is also small hose connect to heat exchanger/oil filter.
By disconecting this hose you get other 3q out. Pretty good from 9q total system.
