Old 03-02-2005, 01:00 AM
threedd97's Avatar
threedd97 threedd97 is offline
Send a message via ICQ to threedd97 Send a message via AIM to threedd97
Wiring my amp
What gauge wire should I use with my ZRS-8? 4 gauge? What gauge should the ground be too? Or should I up to 2 gauge? Also, would the fact that my box being like 2-3 inches from the rear of my trunk muffle the sub severly and reduce performance? It's only like that temporarily unitl I get some longer RCA's and a longer power lead and ground.
UNOFFICAL AUDIO BRAND RATINGS
My life is composed of the worst luck known to man.
Disclaimer: My knowledge of car audio is questionable, but it usually sounds great to me.
'98 Grand Prix GT 4Dr
'06 XXX 12"
Possibly a Cadence ZRS-10
Pioneer DEH-5500MP
Old 03-02-2005, 01:09 AM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Re: Wiring my amp
Some guy on the internet has made a pretty convincing argument that the closer to the back of the trunk of a car the front of the sub is, the better the response curve is (much smaller dips and spikes in the frequency range). Generally with wires, bigger is better, but 4 gauge will take 1500+ watts or so just fine. The ground should be the same gauge as the wire coming from the battery.
I need to add your little disclamer into my sig....
edit... well, added something, anyway. I actually got over 500 characters in my sig while adding it! It sure didn't look like it... I had to cut some stuff out to make it fit.
Old 03-02-2005, 04:41 AM
threedd97's Avatar
The bullets and the double spacing add to the characters I believe, or at least the bullets do. And they add a lot.
I think I have enough slack on my RCA's to move the amp to the back of the trunk near the bumper and the box towards the rear seat. I know I have more than enough 4 gauge to work with, it was just the RCA's worrying me. My remote wire is really long so there's no problem there. It just sounds so weird at certain frequencies. It might just be the box being shitty (although I think it's actually built pretty well) or the fact that sub is being muffled by the side of the trunk it's facing 2-3" from. I think the latter of the two is the problem. Fine tuning the amp I just don't know how to do, which is posing a real problem.
'06 XXX 12"
Pioneer DEH-5500MP
Old 03-02-2005, 08:15 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Wiring my amp
4awg is the minimum you should use, 2awg would probably be better but 4 should do fine
you also want the sub facing the rear with the cone a few inches away from the trunk lid, in a sedan this should give you the best response and output.
what do you mean it sounds weird at certain frequencies? where's your lowpass set? how big is the box again?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-02-2005, 12:17 PM
threedd97's Avatar
The box is 28w x 16h x 24d. I dunno what ANY of my dial controls are set at or what they should be set at. But when certain songs play and a certain bass line hits it sounds like it's messing up. Hard to explain for me. I also don't see how I can get a better response. Wouldn't it muffle the subwoofer if it was nearly right up against the side of the trunk? I mean there is no where for the air in the port to go practically.
Where can I find some nice 2 gauge wire at?
'06 XXX 12"
Pioneer DEH-5500MP
Old 03-02-2005, 01:27 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: Wiring my amp
Car Audio stores, Internet....How do you not know where your controls are set at?
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 03-02-2005, 02:17 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Wiring my amp
www.weldingsupply.com
OR
www.knukonceptz.com
OR
ebay
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 03-02-2005, 02:27 PM
threedd97's Avatar
That stuff at knu is compressed. Can the end still twist into a round form to fit into the connection on my amp?
'06 XXX 12"
Pioneer DEH-5500MP
Old 03-02-2005, 02:28 PM
ngsm13's Avatar
Re: Wiring my amp
Yup, it's GREAT stuff!
NG
