Old 03-01-2005, 10:18 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
metro engine install and surge fix
bought a 93 geo metro the other day that had a pretty noisy knock and smoked like crazy. i drove it home and prayed on the way home i wouldn't pass a cop because the thing was smoking like mad, used almost a quart of oil in 7 miles. anyway...bought one of those JDM engines ($300 with 1 year warrenty) pulled old engine out, swapped the intake and exhaust manifold over and dropped the new engine in, took about 5 hours to swap everything over and get it running (i love my new car hoist :-) )
found easiest way is to pull the engine and tranny as a unit and split it on the floor. after i got it in and new engine fired up at part throttle it would rev up and down about 500 rpm all by itself, wouldn't do it at idle or past 1/2 throttle. also check engine light wasn't on. unplugged the TPS ( that kicked the check engine light on) and tried throttle again, was doggy but no more surge so i grabbed a spare TPS i had on another throttle body swapped it over and it runs perfect now. sure glad i have a ton of spare parts, they wanted over $90 for a new one.
Old 03-01-2005, 10:35 PM
tude123 tude123 is offline
Way to go 'vette! Quick question, did you do your entire engine swapout in 5 hours? If it did you're a lot faster than I am. It usually takes me an entire weekend (including a new clutch kit).
Old 03-02-2005, 01:13 AM
Crvett69's Avatar
Re: metro engine install and surge fix
pull old one out (1 1/2 hour)
transfer intake, exhaust and clutch to new one (45 minutes)
install back in car (3 hours)
times are rough guess, took just over 5 hours total
Old 03-02-2005, 09:53 AM
geozukigti geozukigti is offline
I need a car hoist I did mine with a craftsman wrench set, all by my lonesome, lol. But, I had to change everything under the hood, so it took me about a week(2 hrs/day for a week) That engine technically is light for an engine, but when you're lifting it into the engine compartment all by yourself, DAMN, is it heavy
Old 03-02-2005, 10:23 AM
Crvett69's Avatar
i do enough engine swaps that i have a engine hoist
Old 03-03-2005, 12:50 PM
papajoe2001 papajoe2001 is offline
Autozone wants $125 fo ra TPS. Does anyone have a spare they would like to get rid of cheaply? Apparrently I need you.
Old 03-03-2005, 03:06 PM
Crvett69's Avatar
what year metro do you have, i might have a spare
Old 03-03-2005, 03:10 PM
I have a '92 & '93, both convertibles, but the problem is with the '92. Sure hope you can help.
Old 03-03-2005, 03:18 PM
Crvett69's Avatar
will take a look in my spare parts bin and see what i have and make sure it matches the one on my 92 convertible. will post tonight what i find
Old 03-03-2005, 03:20 PM
Thanks, I appriciate it.
Old 03-03-2005, 04:22 PM
Crvett69's Avatar
i have 2 of the same style left, whats the part number on yours, should be 18590-?????
what are last 4 or 5 letters and numbers?
Old 03-03-2005, 04:32 PM
I'll look when I get home tonight. Thanks Crvett69
Old 03-04-2005, 10:12 PM
Crvett69's Avatar
find those numbers yet?
Old 03-07-2005, 08:38 AM
Sorry for the delay Crvette69, got called out of town unexpectidly. I will get the numbers this evening.
Old 03-12-2005, 11:29 AM
Crvett69 P/N is 198500-0450. Sorry again for delay. Just a bad week.
