blinker problems
my 1999 honda civic coupe's left side front blinker does not work. rear blinker ok as well as right front. also i noticed that the left dash indicator is flashing faster than the right, bulb is lighted when headlights are on. need help. i'm stupid with cars
Re: blinker problems
The indicator light is blinking faster because the second filament in the bulb ( the one that flashes when the turn signal is activated) is blown. Replace the bulb and your problem will be fixed.
blinker problems
THANK YOU SO MUCH!! i'll do what you suggest ok?
the best thing to do is go under the fuse boxe and make sure the wires a connected then make sure the wire to the front blinker is connected. Check bulb, check bulb harness. Connect a amp meter to bulb harness to make sure it is getting any energy at all.
if a bulb isn't lighting the BEST thing to do the FIRST thing to do, is change the bulb. if that doesn't fix the problem, THEN go thru an electrical circuit diagnosis. u could spend as much as 30 minutes testing a complete circuit (power feed, fuse, switch, relay, wires, and all the conectors between, and the ground), and get to the end and it just be the bulb was burned out. that takes 5 min tops. i guess if u get payed by the hr though, u'r way would be the better way to do it. but then again, after a while i think u'r service manager would catch on and u'r ass would be gone. |
