Go Back   Automotive Forums Car Chat > Car Buying Q&A
Car Buying Q&A Ask a question, get an answer; it's that simple. Visit AutomotiveHelper.com for useful car buying tools and research.
Old 03-01-2005, 09:21 PM
carebears2282 carebears2282 is offline
Send a message via Yahoo to carebears2282
Question transmissions compatability
my tranny went out today, I need to know which trannys from what kind/year of car would fit my 92 olds cutlass supreme 3.4, and if a 88 Corsica tranny would fit in my car?
Old 03-02-2005, 03:21 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: transmissions compatability
I don't know the finer points of this, but I'll spit out what I do know to get you started. The 2.8, 3.1, and 3.4 share bolt patterns, so the trannys will physically bolt up. I'm assuming its an auto tranny...
There are finer points to be discussed. One member observed with his swap that the torque converters carried different part numbers and stall speeds given the different final drive ratio between cars. You should investigate that further to prevent a converter that is too tight or too loose preventing optimal operation.
The other thing he noticed was that the electrical connections were different. One had a square, four-prong connector and the other had a round four-prong. Upon further investigation, he discovered that it was not just as easy as adapting the plugs, the wires controlled potentially different things.
I would say from his experience (unfortunately I can't give you first hand info) that the answer is; physically, yes. It will share external dimensions and bolts. Mechanically, hydraulically, and electronically, I can't say.
Dragging people kicking and screaming into the enlightenment.
Old 03-02-2005, 11:21 AM
thank you curtis73, but im still not sure as to what other cars' tranny's wil fit in mine.
