Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-01-2005, 08:36 PM
atomicpulse's Avatar
atomicpulse atomicpulse is offline
My engine
I just got a 2000 Integra and when I start it, it idles very quite, but when I accelerate in any gear on a flat surface, uphill or down it kind of noisy like pinging sound I guess. I pretty much want to know if this is normal since I have no had an import car before I am not sure what kind of noises to expect. Thanks
Old 03-01-2005, 09:36 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: My engine
No you should not have a pinging sound. What kind of integra did you get? And what grade gas are you running?
Old 03-01-2005, 09:45 PM
Re: My engine
well its hard to describe the noise but i figured since it was almost silent at idle it would be silent when driving but it makes a little noise when driving..
i have a 2000 special edition, and just 87 octane.
could it have anything to do with the oil i run in it? i use mobil 1 5w30 synthetic
Old 03-02-2005, 03:24 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: My engine
try run super and see if that helps. could also be valves
Team Lonely Drivers
Old 03-02-2005, 04:03 AM
Re: My engine
The car only has 27874 miles on it as well.. which is why I ask if it idles very quite should there be alot of noise while driving? Runs fines..
Old 03-02-2005, 11:56 AM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
Re: My engine
i highly doubt its the valves...it would sound like that at idle 2, sounds like cheap gas, try 89 or better, and 5w30 should be fine, just make sure u have 4qts, might want 2 dbl check timing 2
Old 03-07-2005, 09:19 PM
michael4mbell michael4mbell is offline
Send a message via MSN to michael4mbell Send a message via Yahoo to michael4mbell
Unhappy Re: My engine
Waz Up Everyone Im New On Here But I Really Need Help My With My Integra It Turn Off After 4000 Rpm's Help Please
Old 03-08-2005, 12:03 AM
Re: Re: My engine
could you be any more vage, we need alittle more info
Team Lonely Drivers
