Go Back   Automotive Forums Car Chat > Lincoln > Navigator
Old 03-01-2005, 08:15 PM
lgardner55 lgardner55 is offline
subwoofer not playing
i've got a 01 navigator and i got in my truck the other day and i realized my woofer was not playing. if the woofer is blown should'nt it still play and just make a racket sound. how can i tell if the factory amplifier is still working? help!!!!!!
Old 03-05-2005, 08:41 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: subwoofer not playing
Yes you car kinda right. More than likely either the amp puked or a fuse blew. But, I've seen speakers just up and quit with no other noise.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-14-2005, 03:34 AM
Timtickle Timtickle is offline
Ive Got A 99 With The Same Problem. Please Post Your Results.
Old 04-15-2005, 07:29 AM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Re: subwoofer not playing
Ive got a 98. Last year the sub blew and i ended up buying an 8in sub for real cheap online and installing it. Its a big pain, The subwoofer is attached to the box on the back fo the enclosure as well as the front and the amp is mounted to the left of the subwoofer underneigh all the pannels. What i would do if it was mine would be check my fuses. I dont recall seeing an inline one buy i may be wrong. My best guess is your amp shot crapps. The amps from the dealer are very expensive. I would suggest pulling that whole pannel off and seeing how much room you have for and aftermarket amp. All you will need is a 200 watt amp at the max. If you live in the kc area i can replace it for you in about 2 hours. I wouldnt charge but 80 bucks. which is nothing compaired to what the dealer wanted. they told me they usually charge around 600 for replacement of the sub and amp. Or you can try it on your own and i can give you some tips if your at a loss. well good luck
Old 06-26-2006, 11:09 AM
navigatorguy navigatorguy is offline
I have mine for sale it works and i have factory amp if you need it let me know. my email is [email protected]
