Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-01-2005, 07:36 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
Are Ground Kits Worth It?!
1996 Mitsu GS Spyder Eclipse 2.4 L 4G64
I am debating weather or not to purchase a ground kit like this one
http://www.x3racing.com/product.asp?pid=GW-RAL-RD
some people say it is a waste of money others say that it adds 5-9 hp and stabalizes some electrical things in the car but is it worth 40 dollars plus shipping and has anyone had any experience with them?
thanks,
Sean
[email protected]
www.serious-sounds.com
www.cardomain.com/id/trueeclipse
Old 03-01-2005, 07:53 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Are Ground Kits Worth It?!
I highly doubt you'll gain 5-9 hp from it, but replacing and adding a few grounds can only make things better. $40 isn't that bad of a deal, but you can make them yourself if you'd like. I say go for it, couldn't hurt!
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 03-08-2005, 07:48 AM
slowgsowner slowgsowner is offline
I recommend them. I have them on all my cars at the moment (apexi) and while I can't say they've added power I can say my cars tend to pick up a little better (little being the key word) than before I had them installed. less hesitation and for some reason after I installed them on my gsx, the miss I had somehow went away. ??? go figure. I installed mine with the intent to make the elect. system more stable. I have seen what can happen to cars ecu's when running on a weak/ damaged ground. But to be quite honest you can make your own straps... and save money.
95 gs booosted ....no time yet
99 gsx stock
71 mustang 429cj...9.94
84fiero/diablo conv. in proggress
Old 03-08-2005, 01:46 PM
How would one going about making their own for cheaper and would it look as good as what is on the market?
Old 03-08-2005, 10:19 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
http://www.dsmtuners.com/forums/showthread.php?t=75889
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 03-09-2005, 10:40 AM
oxygen800r's Avatar
oxygen800r oxygen800r is offline
i grounded my gst once i noticed that the headlights would dim when i mashed the pedal.
once i installed the wires, it stopped.
didn't really notice much of a difference anywhere else.
i made them myself as well. it's freaking easy and there's really no good reason to spend $40 on a bunch of wires unless you have money like that. you can end up spending 1/2 that if you do it yourself.
