Old 03-01-2005, 07:07 PM
89rstbi 89rstbi is offline
Send a message via AIM to 89rstbi
rear end gears
i just bought a rear end from a guy who said it was 373 but im almost 100 percent sure its not....its a 9 bolt does any one have any clue where i can get ring and pinion gears???/
Old 03-01-2005, 07:14 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: rear end gears
no, but if you open it up and count the number of teeth on the ring and pinion, the ring should have 3.7 teeth for every tooth on the pinion. that's how you find out.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 03-01-2005, 08:50 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: rear end gears
if you dont want that 9 bolt you can always send it to me for my birthday present
Not sure weather or not they offer 3.73 gears for the 9 bolt rear. but you can find all the parts you need, and alot of info from www.9bolt.com. This guy is the one stop source for 9 bolt rear parts and will be able to sell you probly just about anything youll need. If im not mistaken the only gears ive ever seen for this rear end are 2.77, 3.27, 3.45, and 4.10 only the first three were factory equipped. but there could be some aftermarket offerings i dont know about.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 03-02-2005, 11:36 AM
Re: rear end gears
aight i found out that the gears are 2.77 so this rear end is mainly useless unless ui can find a carrier for it...if anyone has any suggestions let me know
Old 03-02-2005, 09:32 PM
89IROC&RS's Avatar
Re: rear end gears
ive seen a few three serise carriers and gears on ebay, but that website is the best place i know of.
Old 03-09-2005, 08:56 AM
Re: rear end gears
i just bought a series three carrier with 327 gears for 75 dollars...i had it checked out when i got it anmd the guy said was was in great condition...so im all set wit that now....again thanks for the help
Old 03-09-2005, 10:49 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: rear end gears
glad to hear its workin out for ya...
*Better power-to-weight ratio than a C6 corvette*
Old 03-09-2005, 12:53 PM
Twitch1's Avatar
Twitch1 Twitch1 is offline
Re: rear end gears
Don't forget if you have altered the original stock tire/wheel height it will change the final drive ratio. Smaller diameter= lower ratio.
1973 Z-28
1965 Nova
1950 Packard
1996 El Dorado Touring Coupe
There is no substitute for cubic inches
