Old 03-01-2005, 04:24 PM
duranrp duranrp is offline
Brake light keep's coming on during.....
Normal driving. I thought maybe the brake handle switch was getting stuck cause its been really cold out here. But later that night i went ahead and disconnected the switch from the brake handle side and it still popped up on the cluster whenever i hit the brakes in short distances. Or when i make sharp turns at high speed. I know there is a switch on the pedal side, you think that can be the case in why the brake light keeps popping up. I was thinking maybe i can take the light out fromt the cluster cause its driving me crazy. Also are the brakes that advanced to have a signal on the cluster when something is wrong with them from normal driving. Or is it from the brakes itslef is it time to be change you think. Help a brotha out thanks a lot pe@ce rich
Old 03-01-2005, 04:45 PM
angels7113 angels7113 is offline
Re: Brake light keep's coming on during.....
when my brake light kept going on and off all i needed was to add more brake fluid have you checked that.
Old 03-01-2005, 04:52 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
There is a float in the MS Resivore... It has a sensor on it that when it reaches a certain low level, it causes the light to come on. That would be your first place to look.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 03-01-2005, 06:26 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if its down, watch out, you could be leaking brake fluid
Team Lonely Drivers
Old 03-01-2005, 06:35 PM
thanks for the input guys
As soon as i get off work all take a look at the level. All make sure and post up any details thanks guys appercite it pe@ce rich
Old 03-01-2005, 09:16 PM
Team PHATBOYZ's Avatar
Team PHATBOYZ Team PHATBOYZ is offline
Send a message via ICQ to Team PHATBOYZ Send a message via AIM to Team PHATBOYZ Send a message via Yahoo to Team PHATBOYZ
Yup, im guessing it's your brake fluid running low. That's all. Mine used to do that too, I would refill my brake fluid every week, until i figured out what was wrong with it. It was that my back brake line was leaking and my brake cylinder had a leak too. So i replaced it and it's fine now.
4TH GEN CIVICS ROCK
