Old 03-01-2005, 04:11 PM
desert_520_flower desert_520_flower is offline
Question i need the firing order for a 2001 grand am 2.4L anyone???
My service engine light came on. i took it to autozone. they read the codes and said my #1 cylinder was misfiring. so im going to replace to plugs, and boots . can anyone help?
Old 03-01-2005, 05:16 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: i need the firing order for a 2001 grand am 2.4L anyone???
Why do you need the firing sequence? Well I'm pretty sure it's 1 & 4 simulateounsly, and then 2 & 3 simlultaneously.
Old 03-02-2005, 08:51 AM
Hoags's Avatar
Hoags Hoags is offline
It's a simple replacement, you can't screw up the wires. the Ignition module only allows for the plug wires to go on one way. The wires are not actually wires they are more like plug boots. If I'm not mistaken when you pull the cover to get to the plugs the cylinder numbers are on the engine block.
