Eibach: Sportline or Prokit?
Can anyone tell from my pic (estimate of course) how much lower my car is from the factory height? The car was lowered by my bro and then cut those springs but I want to know which kit to buy so I can get a basic picture of how much lower the car will be.
For ex.: If the car is lowered like an inch right now then I would get the prokit most likely, but if the car is only like 1/2 inch lower than I would get the sportline. I just dont want the car to be slammed too much cuz speed bumps already give me enough of a problem. Or, is there anyway to actually find out? Like measure top of wheel to fender type of thing? If so, does anyone know what the stock height is with stock size tires, 195-60-15. Thanks in advance.
Re: Eibach: Sportline or Prokit?
Tell me if you guys think this would be accurate. I found out that the factory height of my car was 50.8". WOuld I just be able to measure the current height of the car with like measuring tape and dtermine how low the car is now. Like if I measure it and the car is like 49" then its already been lowered like 1.8". You think that would be accurate enough or do you guys know what else, if anything, can be done?
I don’t think it would be that accurate. It will be hard to measure from the top of the car to the ground. If your buying a kit they should tell you how low the car will be from stock. Some will even give the ride height from the ground. My guess would be though judging from the pic that it wont be too much lower then your car already is now.
![]() Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows |
I already know that the sportline drops 2.2" in front and 2.1" in back, while pro-kit drops 1.8" in front and 1.6" in back. Just trying to get an idea of how low car currently is.
Ok looking at your car and stock 240s I would say your car is proabably about the height of the pro-kit. If you want something lower then what you have get the sportline.
Edit: Get us a side picture so someone can photo shop it
I'll take a sideshot tomorrow but still not sure if anyone can or will photoshop it.
the way you measure how much a car is dropped is by taking a tape measure and measure from either the top of the rim or hte center of the rim to the fender.
303whp stock internal KA-T 94 Acura NSX Best E.T. 13.559 Best Trap speed 107.62 mph |
get coilovers, so you can adjust the height yourself!
yeah but what do I compare that number too? Do you know what the factory measurement is for that same distance? Where would I get that info??
just like that huh public enemy. Why didnt I think of that!! If only I could, If only I could.
going off the top of my head... stock s13 tire gaps are bigger than the gaps of 5 cent whores down hotel st.
it's probably more than 2" from the top of the wheel to the fender... i don't know why they made it like that in the first place... it's nasty. |
why dont you just look at cars that already have sportlines or prokits on them to see what you like more.. the prokit basically doesn't make the front end look like is up in the air so much and lowers it a little. the sportlines lower it more obviously. i'd say get the sportlines, imo they look better.
http://www.cardomain.com/id/dbo240 ![]() ***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE*** |
well atleast ur springs were not cut 2 much look at my car on my sig (ill post my pix on cardomain still updating it) that is 2 dropped the front springs are real close together i cant even go over a bump that much im going with an adjustable suspension system. soon real soon
u cant tell that much about mine cuz of the angle my friend used 2 take the picture. but ill post some of the ones i took. |
