Old 03-01-2005, 01:52 PM
n8s95gsx n8s95gsx is offline
Down Pipe help
Ok, so im looking for a down pipe on ebay for my GSX and i need some suggestions. should i get the one that eliminates the cat? i dont want to eliminate my 2nd o2 becasue it will pop the CEL and cause my MPG to suck Azz. Is there a way of getting around that? any good brands i should be looking at? thanx guys
Old 03-01-2005, 02:24 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Down Pipe help
i posted a thread less then a month ago asking this question.
i was looking for a 3in mandrell DP that did not eliminate the cat. after calling many vendors including some on Ebay, there are few who offer such a downpipe RRE sells one. Basicly, buy the one you want for $130 cut the extra pipe off and have it flanged to meet upto your cat. the local muffler shop said they'd take care of that for around $50.
DSM geek
Old 03-01-2005, 02:38 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Down Pipe help
The second O2 sensor has nothing to do with fuel consumption. The front O2 is the one that the ECU is concerned about when determining fuel delivery. The 2nd O2 is designed to confirm that the cat is doing it's job properly. If you eliminate the cat, wrap the rear O2 in Al foil and hang it somewhere (leaving it plugged in) the ECU will not throw a CEL. You will however fail emissions if they see that you have no cat. So if emissions isn't a problem, eliminate the cat and wrap the second O2.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-01-2005, 03:05 PM
tsi4444 tsi4444 is offline
RRE offers the short downpipe that u can put their highflow cat on.
Old 03-03-2005, 08:29 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
Re: Down Pipe help
RRE also sells the 90 degree bend for a custom downpipe. they also sell all the flanges youll need. if you kno somebody that can weld. you can get all the material for pretty cheap
Old 03-04-2005, 04:22 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Down Pipe help
Its acutally not a 90 degree bend, I think its more like 80 degrees. At any rate, it does make fabricating a DP a little easier than using a typical 90 degree bend. I'm sure you know this modder, just pointing it out for the people that havent built their own exhaust.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-05-2005, 09:04 PM
Re: Down Pipe help
i would highly recommend buying the parts and finding someone that can weld pretty decent. check out what RRE (www.roadraceeingineering.com) has to offer. occasionally i see a few apexi n1s on ebay but even for half price those things are a waste of money.
