Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 03-01-2005, 01:47 PM
Dana G. Dana G. is offline
Missing and Backfiring
I have a 1997 Jeep wrangler, 4 cyl. I was driving down the road and it started missing and backfiring really bad!! The backfiring was so loud it sounded like a shotgun goin off! I had to pull over it was missing so bad. Anyway, my check engine light came on! Please help!
Old 03-02-2005, 09:05 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Missing and Backfiring
A sudden problem like that may be a sensor gone bad. I'd have the shop check the crank position sensor and if there is one, the camshaft position sensor.
Were there anything else odd that you noticed prior to this sudden problem?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-02-2005, 12:34 PM
Nothing else really, just the missing and cutting out, and backfiring! And the check engine light, i had a guy test it, and he said oxygen sensor??? Does this sound right, he also checked the coil wire and he said fire was shooting from the end of it! He also said the computer read cylinders 1 and 4 had something wrong with it! But i dont know cause, do u think the oxygen sensor could be giving them problems????
Old 03-02-2005, 12:42 PM
I haven't heard of the O2 (oxygen) sensor causing those types of problems, but it could be contributing. How long has it been since you had a tune up?
Were there any symptoms prior to the episode on the highway?
Old 03-02-2005, 03:40 PM
Probably about a year ago i put new plugs and wires on it! could be the plugs fawling out?? it had a little miss to it about for about 2 or 3 months before all this happened!
Old 03-02-2005, 10:08 PM
It sounds like the problem might have been getting worse as time went on? The plugs might be falling out if they weren't tight enough but that's not often the case. Wouldn't hurt to do another tune up and check all that out.
Old 03-03-2005, 02:39 PM
i tested the plugs and the #4 plug seemed like it didnt have as much spark to it as the others, so im goin to try a new plug! Could my coil wire have anything to do with this?
Old 03-03-2005, 03:33 PM
Mmm, it might, but if one plug seemed weak, (and especially if the plugs haven't been changed for the last 30K miles) I'd consider changing them all out.
Old 03-03-2005, 03:47 PM
thats probably what i'll end up having to do! im goin to pull the # 3 plug out and try it on the # 4 cylinder and see if it fires any better, then i'll know if it is the plug or the wire!
Old 03-03-2005, 04:06 PM
I'd check the cap also, if it's cracked it could cause the problem, especially if it's damp outside.
Old 03-04-2005, 07:21 AM
Well, i think i figured out the problem! The # 4 wire was losing fire put a new one on it and it seems to be running fine. no missing or anything, (yet)! But my check engine light came on again, could this be because the oxygen sensor?
Old 03-04-2005, 07:31 AM
Cool! Glad it was just the wire.
Check engine light could be the O2 sensor; have you noticed your gas mileage going down lately?
Old 03-04-2005, 09:02 AM
Actually i have, i use to get about 13 or 14 mpg, cause i have 31 inch tires on it, now im only getting about 8 or 9 mpg. Do u know how many oxygen sensors there r on a 97??
Old 03-04-2005, 10:06 AM
I'm not sure but I think there's only 1. Single exhaust; the O2 sensor will be just before or just after the catalytic converter (both if you have 2 sensors).
As a temporary fix, you can unplug the O2 sensor until you get the new one. Just make sure the wires are held up and away from anything that could damage them.
