Old 03-01-2005, 02:44 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
too frustrated to go on..
Well I finally think I have the timing all nice and perfect. So thats good.
The only thing is that the timing belt is really loose a few times around when I turn the crank.
Half the time its just about perfect, and the other half its really loose, and it slowly starts to slip off just by me manually turning the crank. I am sure if i started the car it would come off easily.
I tried tightening the tensioner, that I finally got back in after taking the belt off again, but it doesn't seem to even do anything.
Travis
Old 03-01-2005, 03:52 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: too frustrated to go on..
You sure the belt is on the correct teeth? I'd assume if it was off 1 or 2 that it'd be tight on half of it and loose on the other half. Maybe move it back 1 notch towards the loose side and see if that does the trick?
Old 03-01-2005, 03:56 PM
crv-tec crv-tec is offline
You can do it!!! Sorry I felt he needed some motiviation
'nuff said
Old 03-01-2005, 05:55 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
You have to spin the motor counter-clock wise, on the crank pulley, until the cam moves three teeth (meaning the cam moves three teeth from the plane of the head), then you tighten the tensioner at that point. It helps if you have the lower timing cover off (which I'm sure you do...) Another thing, try to make sure that all of your pulleys are lined up. If the belt is walking off, you might not have a pulley that isn't quite tight enough or is not placed correctly. I'm not trying to make you feel dumb... My dad had to help me with mine (yes, it's a d15a3, but my manual is for the 84-91 civic/crx's), so don't feel bad if you have to go back and fix something and start the process over. You'd much rather spend the time to fix it now, then spend more money on another engine when the valves slap the pistons.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 03-01-2005, 07:25 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
timing belts are easy, for hondas ive done 5 already. gotta turn it counter clockwise to get the tension. turn it alittle, then tighten tensioner. then try spin the motor and see if it starts to jump
Team Lonely Drivers
Old 03-01-2005, 08:56 PM
SiZ's Avatar
SiZ SiZ is offline
Give up, quit. No one here cares.
Old 03-01-2005, 09:04 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Re: too frustrated to go on..
ROTFL!!!!
haha come on Remember the little train that couldnt get up the hill? haha
Just give it a break, get some food, a sledge hammer and then come back. Well when i stripped the bolt on my tensioner i took off the water pump and pushed it along the belt bolted it back and viola!!!!
Old 03-01-2005, 09:10 PM
Onimacus's Avatar
I'm already saving for a new engine, that isn't a big problem. But I just wanted to be able to take this car out a few times before i pull the motor and have a huge mess in my garage hehe.
It does jump when i spin the motor, so I am going to try do move it one tooth over and see if that fixes it. Just gotta wait for my buff friend to come over and help.
Travis
